725 patient compartment lights
Post by prim1 on Aug 20, 2006, 3:21pm
The surgical light, dome light and ventilation blowere in the patient compartment have quit working. Any suggestions of what the trouble might be?
Re: 725 patient compartment lights
Post by tacomainoh on Aug 20, 2006, 3:35pm
uhmmmm
wiring trouble??? just a guess.
seriously though, check your grounds.
Post by compexp on Aug 20, 2006, 3:45pm
there is a small panel in the front of the compartment, left of the door as you look from the back. There are 3 circuit breakers in there - thermal type. I would suspect your problem is there, as power is fed from the batteries to those breakers via a single line.
those breakers handle the surg light, blowers, and rear light.
Post by jfnemt1ff1 on Aug 20, 2006, 8:28pm
Also check the breaker that is in the Batt. box it supplies power to the abowe breakers.
Post by compexp on Aug 20, 2006, 11:32pm
Interesting - mine didn't have a breaker in the batt box.
Post by jfnemt1ff1 on Aug 21, 2006, 6:44pm
My 67 has a house type buss fuses that comes off the pos batt cable and goes to the cb in the ft wall. The wire diagram shows it.
Post by fasteddie on Aug 21, 2006, 6:48pm
Mine also did not have the circuit breaker by the battery , but I installed one just to reduce the risk of a electrical fire from a short .
