Nice compact addition. And clean fresh paint is great to look at. Thumbs up!
You know sh*t is starting to get real when you pick up your brand new badass custom length 1410 series driveshafts! [emoji851]https://uploads.tapatalk-cdn.com/202...5f33eea736.jpg
Now that is some serious one ton stuff!! I just spent the last three evenings studying driveshafts and Universals in 1 ton 101. :happy10:
Very nice!
I don’t know how they could call these 1 1/4 ton trucks with these little driveshafts... The 1410’s make the original seem tiny!https://uploads.tapatalk-cdn.com/202...f778c7a1fa.jpg
I know right... Those 1310's can only handle so much power. I think the spring packs and rear axle capabilities combined with how much could be loaded into the bed helped get it's 1.25 ton capacity. Going 1410 is sort of a correction. 1350's and 1410's have the same huge bearing caps at 1 3/8 dia,
and huge cross section that gives it the strength. 1410's being wider can offer way more angle forgiveness which is pretty cool. 35-37 degrees verses 20 degrees for a 1350. 1410 yield torque is a stunning 2700 foot pounds. Then you have tube thickness. 0.83, 0.95 and 120 wall. I would imagine M715's hopefully have .120 wall tubes.
Beautiful parts. I hope to get that far soon.
It’s amazing how many little odds and ends are needed to finish all the details. A few stops and another shipment from Summit Racing and she might just be ready to fire next weekend! Then on to the brakes and getting the interior together!
https://uploads.tapatalk-cdn.com/202...6438f84496.jpg
Oh my, that picture has me drooling. Looking good!:cool:
I really need to stop getting side tracked. I was shopping on Summit racing the other day and was looking at cast aluminum valve covers. I’m sick of the seepage from the stamped steel ones on the motor, so I grabbed a cool set of satin black cast aluminum. Well, that lead to this. Another day “wasted” on something I really didn’t need to do. It would have been a hell of a lot easier if I had done it before paint and dropping the motor in for good! Oh well, it will be awesome when it’s all done! [emoji2369][emoji2361][emoji16]
https://uploads.tapatalk-cdn.com/202...bc38c69bd5.jpg
https://uploads.tapatalk-cdn.com/202...9fe3cae098.jpg
https://uploads.tapatalk-cdn.com/202...57f30646da.jpg
I thought it was a good day to work on the old girl today, and thankful that I have the freedom to do so!
Got my clutch linkage fabbed up and installed. I’ve never done a mechanical clutch before, so hopefully this works out, lol.
Also got a flywheel shield fabbed (with integrated clutch return spring mount!) and started on the exhaust. After the exhaust I think the fab work is pretty much over except for seat mounts. Then onto wiring and getting the dash/column in.
https://uploads.tapatalk-cdn.com/202...334df7d690.jpg
https://uploads.tapatalk-cdn.com/202...992590981b.jpg
https://uploads.tapatalk-cdn.com/202...80f5fa3cf0.jpg
It’s glorious... good work Sir!
