Source for Knuckle Seals & Kingpin Bearings
I just stumbled across this information on BinderPlanet: Torque King 4x4 has a bearing & shim kit to fit Dana 60 closed knuckle axles, as well as a felt seal kit, and a grease apparently made for closed knuckle applications.
Bearing & shim kit: QK4618
Felt seal kit: QA4936
Lubricant: 777
http://www.torqueking.com
Apologies if this information has been posted before.
Torque king is great, but......
I ordered the kit that was recommended for the Dana front end, the problem is, is there is a difference between the commercial Dana and the military Dana front end. The lower bearings and races are smaller and have a different taper in the military version. Just keep this in mind, when ordering. Be specific with Roy. He is very helpful and knowledgeable.
