Clutch fork on a swap
Hello friends! Swapping a Chevy 230 out for the Tornado. Paid 1300 for parts from Novak but it DID NOT include the clutch, pressure plate, or fork....I figured out I need the Chevy 11" clutch assembly, but what about the fork? Should it come from the 715 or a Chevy fork? Keeping the T98 and have a bellhousing for bolting to both the Chevy and the T98. Thanks!
Doesn’t the Novak kit use the stock Kaiser bell housing? If so, the stock fork should work.
I have a Chevy fork. Check the part num ... it will work if you use a standard 350 bellhousing.
https://www.ebay.com/itm/30405221261...mis&media=COPY
Edit: nvrmnd I see you went with a 6.
Sent from my SM-G781V using Tapatalk
