Moving the brake light switch from the orginial spot to under the dash on the brake pedal. Was hoping someone has an easy solution. Looked in the NAPA book for some ideas. None really jumped at me. Pictures and part number if possible..
That's seems like a simple solution. And I thought what I did was simple but that doesn't look like it requires any welding.
I used a brake light switch from a Jeep CJ and welded a tab to the steering column on my last 2 trucks.
https://www.amazon.com/Omix-Ada-1723...omotive&sr=1-5
Love to see a few picb!!
It took some searching but I found these:
http://m715zone.com/vb/picture.php?a...pictureid=1002
http://m715zone.com/vb/picture.php?a...pictureid=1003
And if I recall correctly the brake light switch wires were long enough to pull from their original location and reach the new switch.
THANKS, so far. Questions: Did u soder wires to outer tabs?
If u sent a picture, did not come thru.
I cut off the stock connector and crimped on a female spade connector to the wire.
Link to Amazon for spade connectors;
https://www.amazon.com/dp/B010GWZOUW...osi&th=1&psc=1
My album where the pictures are is here in case they are not displaying correctly in the thread:
http://m715zone.com/vb/album.php?albumid=70
The message above that I deleted was incorrect, sorry.
Brake light switch pictures
Here's some pictures I took this am of the Amazon switch. hope this helps.
