do any of u fellas have a picture of the correct antenna mount for the 715? i found a fella that has several different styles for sale, but we aren't sure which is the correct style. thanks in advance.
I guess it really depends on the antenna base you plan on using. An AB-15 or a MX-6707 would be the 2 most popular ones. The MX-6707 uses the "sugar scoop" mount with the stand-off mount for use on the bedsides of a M715 as were the AB-15 would use the triangular mount that was also the same ones used on M37s.
thanks dave. the sugar scoop is the 1 i'm after. i thought it was the correct style but wanted to be sure.
See this post by me;
http://www.m715zone.com/vb/showthrea...hlight=antenna
Would that antenna work for a CB antenna?
