Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: a few questions
    Sep 2008
    santa rosa, california
    Default a few questions
    so me and my bro found an m715 and it's not 100% but close and it really needs new tires before even moving it
    i was wandering what size the stock rims are
    and if i could use a chevy 6 lug
    The M715 rims are their own thing altogether. 6 on 7.25" pattern if I remember correctly. Not even close to a Chevy 6 lug pattern.
    They are 16 inch rims and are a lock ring design.
    The bolt pattern for the wheels is 6 on 7.25 inches with a 5.5 inch center hole. The stock studs are 5/8ths inch diameter with 18 threads per inch, fine thread. The stock rims are split rims that measure 16 inches tall, 6.5 inches wide and have 5.5 inches of backspacing.
    No Chevy pattern fits.
    Sep 2008
    awsome thanx guys
    Sep 2008
    i have another question so since these rims are super jank what have you guys done about it
    like swap shafts or what else/where did u get your parts
    Well, you can try to find a set of rims (I went this route, and now have many spare rims). You can pay to have custom set of rims made with a solid center with the M-715 bolt pattern (a member here got some from Marsh I beleive for roughly $100 per rim). Or you can swap axles to something with a different bolt pattern. Those are pretty much your options.
    68 M-715
    67 M-725
    Jan 2007
    Georgetown, CA
    Chuk E, are your rims damaged? It is important that you understand the terminology, . .these are LOCK RING wheels, which is different from a standard SPLIT RIM, and much safer. They were used on these truck sprecifically so that the tire could be changed in the field with hand tools if needed. That being said, to swap tires, your best bet is a truck shop, as they have experience with this type of wheel. These are heavy, strong wheels, . not like the stock stamped stuff you find on a civvy pickup. Here in N, CA, our nearest sizable parts supply is surplus city, in Oroville, . . FYI, . .and welcome to the madness!!
    Sep 2008
    alright thanks for the help guys
    and yes moosejr it is madness
    Jan 2007
    Georgetown, CA
    Chuk E, . . I end up out your way occasionally, . will have to stop by and check out your "score", . ..If you are ever up toward the Rubicon, give me a holler, . . I am sure that mine is probably one of a very few that have been on the rubicon, .. .
    Sep 2008
    oh awsome will do just let me kno wen your down here
  1. Hello and a few questions.....
    By JEEPDAD56 in forum Open Discussion
    Last Post: August 29th, 2007, 12:06 AM
  2. Two Questions
    Last Post: April 16th, 2007, 08:23 AM
