Results 1 to 4 of 4
Thread: That lever on the winch?
    Exclamation That lever on the winch?
    Getting all the small stuff done. Desided to pull the winch cabel all the way out and clean and grease it and that lever is suppose to be an engage and dissigage lever but mine winch works with the lever in ether position? whats up?
    Jan 2007
    Georgetown, CA
    I would guess that the drive is dragging or the lever is not fully disengaging the drive because it locks slots onto pins for the drive. If there is a lot of gunk buildup and no load on the cable, . .it might feel like it is moving far enough to engage/disengage, when it isn't. . .
    canby Oregon
    It sounds like the set screw in the shift fork backed out, or shift fork was installed flipped. If flipped, see if you can go past hole in plate below handle. Mine would disengage then. The thing that stinks is that you have pull the winch to fix.
    Shift forks are bent easily also, infrequent use, then an over zealous smack to get the lever moving again is all it takes.
  1. Show me your winch (BUILT) winch bumpers
    By bluesman2a in forum Modified Tech
    Last Post: June 21st, 2009, 01:45 PM
  2. Need a pic of PTO lever on PTO
    By Duane in forum Stock Tech
    Last Post: July 30th, 2008, 11:49 PM
  3. three lever switch
    By ryanroo in forum Stock Tech
    Last Post: March 20th, 2008, 12:47 PM
  4. Winch Lever Lock question
    By Roger1952 in forum Stock Tech
    Last Post: January 29th, 2008, 07:26 PM
  5. E-brake lever
    By ffdemoss in forum Modified Tech
    Last Post: December 26th, 2007, 07:19 PM
