Was going to put the windshield on today but have delayed. I mounted the new weather strip and it doesn't look right. I have no point of reference since my old weather strip was rotted off. The screw holes line up perfectly, strip to windshield, as well as the defroster slots and side notches, but the strip seems too wide on the outside and it doesn't go all the way under the frame. Almost like it is offset. The pictures below are hard to see the problem but in the first you can see the strip sticking up beyond the outside frame and in the next the outside of the strip. Both are of the same end.(yes, the paint is the same, just flash vs no flash!)
Should the strip go completely under the frame and be exposed on the dash or does it extend to the outside forming a channel?
