Results 1 to 5 of 5
Thread: parking light bulbs
    Jan 2008
    Montreal Canada
    Exclamation parking light bulbs
    I'm missing my dash parking light bulbs .... which is the good number to get somes ??
    Rockwells / Cummins / 3053A
    Combat wheels on 395 XML
    M104A1 trailer
    Jan 2008
    Montreal Canada
    i didn't find with the search fonction ... give another try and find exactly what i was looking for ...
    From Appendix 2, -34 Maintenance Manual:
    Lamp bulb trade numbers:
    Headlight 4801
    Front parking light 1683 (1), 1251 (2)
    Stop, tail, and directional signal 1683 (1), 1251 (2)
    Indicator Light:
    Headlight beam 1829 (aka: high beam dash light)
    Directional signals 313 (aka: light in turn signal housing for the Spartan style turn signal switch)
    Indicator Light:
    Cluster 1829 (aka: dash lights)
    Heater control 1829
    M104A1 trailer
    I used a common 12v bulb in the dash light, but keep the switch on low which is approx half voltage, so they work perfectly.
    68 M-715 MVPA #2710
    12V equivalent to the 24 volt bulb for the dash is: 1892
    We have a list on the site in 6 volt, 12 volt and 24 volt bulbs so one can cross reference between voltages in the same bulb design/application/brightness:
    http://www.m715zone.com/vb/pages/man...rsionChart.pdf
    Jan 2008
    Montreal Canada
    This is great .... thanks a lot
    M104A1 trailer
  1. Bulbs
    Last Post: May 6th, 2011, 05:46 PM
  2. PArking light problems
    By Kamikaze12volts in forum Stock Tech
    Last Post: October 12th, 2008, 07:44 PM
  3. 24 to 12 volt bulbs
    By Chop Parlor in forum Modified Tech
    Last Post: September 11th, 2008, 12:24 AM
  4. Need 24 Volt Bulbs
    By viperman in forum Stock Tech
    Last Post: February 7th, 2008, 01:45 PM
  5. 12 volt light bulbs
    By bdial in forum Open Discussion Archives
    Last Post: February 27th, 2004, 08:52 AM
