Results 1 to 4 of 4
Thread: Vacuum required for windsheild wipers?
    Auburn, AL
    Default Vacuum required for windsheild wipers?
    Does anyone know what the required vacuum to run the windshield wipers? Need to check the old ones.
    My 396 idles in the 16-18 " range and the wipers work great. They work slowly under load and climbing hills so, I would suggest you find a source 15" or higher to test them with.
    I don't think I have seen a spec on the vacuum pump. If I did, I promptly for got it.
    If you don't have a source and don't want to hook it to a regular car engine just to test. Put a T into an air pressure line and that will run them.
    I have never seen a spec either...next time I am near a vacuum gauge and a running truck....
    Auburn, AL
    Thanks Guys!!!
  1. 24v wipers
    By MILRET45 in forum Modified Tech
    Last Post: August 19th, 2009, 12:34 PM
  2. vacuum wipers
    Last Post: July 13th, 2009, 11:07 AM
  3. T-case: Are gaskets required?
    Last Post: November 22nd, 2008, 08:30 PM
  4. Vacuum Wipers
    By rboltz in forum Stock Tech
    Last Post: November 10th, 2007, 01:28 PM
