Results 1 to 10 of 17
Thread: Rear axle u-bolt size
    Jester Guest
    Default Rear axle u-bolt size
    Anyone have the u-bolt size on hand for the rears? I had to cut mine off to get them off. Took off the 10 leaf springs. Rebuilt them with some springs from Fisherman. Left out the smallest spring.
    Gonna bolt them back up but don't know what size u-bolts I need to get.
    I know the outside one will need a bend.
    Washington State
    I think 9/16 s not sure on the length, I can get a measurement tomorrow. The bend was easy in a huuge vise.
    Washington State
    Did you use the slip plate?
    Jester Guest
    Yup - used the slip paint.
    They are a hug diff in size from the beasts I pulled off. That alone should make a huge difference.
    Washington State
    If you used a coat or two of slip plate liberally, I think you'll notice a huge difference.
    I have an NOS pair of rear ones...I'll go measure here in a minute...
    Heres the whole set of numbers from the "more than you needed" file...
    9 inches top to bottom
    .463 inch diameter on the bare threads, .465 inch diameter on the shank, over primer.
    3 5/8 inch inside of the U, left to right.
    1 7/8ths inch of threads.
    7 1/8th inch from end to start of threads.
    Fine threads.
    Should do it...funny the threads are over 7/16ths/.435 and just under 15/32nds/.46875
    What size is that?
    Jester Guest
    Fine threads.
    What size is that?
    Wow thanks. No idea what size that is. Prob some military spec
    As long as I get some that are 3-5/8" inside and at least 9", I should be good.
    Port Orchard, Wash.
    What size is that?
    31/64" Duh....
    -- Tim Taylor
    31/64=.484375....little too big for .464
    29/64=.453125
    15/32=.468...close as one can get without going to 128ths....but we would be looking for a 16th at finest as where do you get a 15/32nds bolt or anything in 64ths?
  1. maddawg308 : Size of fron and rear axle u-bolts?
    Last Post: November 12th, 2009, 01:37 AM
  2. Winch bolt size
    By Barrman in forum Stock Tech
    Last Post: December 20th, 2008, 01:36 PM
  3. 14 Bolt FF Rear Axle Swap
    By BigBlockBurris in forum Modified Tech
    Last Post: January 13th, 2008, 09:54 AM
  4. Need help with the e-brake bolt size
    By Binford in forum Stock Tech
    Last Post: September 13th, 2007, 11:07 AM
  5. Questions about the rear-rear axle
    By Brian Sisson in forum Stock Tech Archives
    Last Post: May 21st, 2004, 08:06 AM
