Hi all,
I have a Stock 1967 M-715 that had a rather nasty oil leak around the timing chain cover. I've since removed the distributor, oil pump, cover, and replaced the gasket, however now that it's back together, I cannot get it started.
We do have spark, it runs on ether, but I'm 1) unsure all of the vacuum lines are routed correctly and 2) fairly sure it's not getting fuel. Suggestions?
