Page 1 of 5 12345 LastLast
Results 1 to 10 of 46
Thread: Isuzu 4BD1T swap
    Jester Guest
    Question Isuzu 4BD1T swap
    These 3.9 diesels came in Isuzu NPR trucks. Looks like a good canidate for a swap. Very similar to a 4BT but revs a bit more from what I have seen. There is also a company that makes a engine/trans adapter.
    http://www.isuzudieselswapper.com/
    Has one of these ever been swapped into a M truck? What are the drawbacks? Pros/cons vs 4BT?
    Jester Guest
    Washington State
    I think your 230 makes similiar power and torque. The only gains would most likely be fuel economy, with an overdrive trans. I think you would lose some off road driveability by changing gears. But the diesel would most likely handle off camber better. But how much off camber can you get these trucks into? You almost ready for a shake down run? I added some adjustments to my hydraulic clutch setup today and it's back on the road after 3 weeks.
    The Isuzu engines are way more available than the 4bt, and in my opinion a turbo 3.9 liter is all you need. I had a mitsubishi fuso FG (4wd pug nose) with a td 3.9 and drug my m-715 back from Montana like it wasn't even there. But is was geared pretty low, would go 60 all day long with any thing behind it. 13 mpg
    Stock 230:
    132.5 HP @ 4000
    198 ft/lbs torque @ 2000
    Jester Guest
    Jester Guest
    Quote Originally Posted by fisherman View Post
    In stock form prob right. But the ability to make more power with "turning up the screw" is interesting. Think you could make 250 hp pretty easy.
    Getting close. Waiting on some parts at this point. Should be good to go after Thanksgiving.
    Washington State
    If you can get one for similiar cost of a small block, BB. I'd think about it. Depends upon how much the adapter stuff is going to be. A small block will make better hp and torque numbers, cheaper easier install. And this is from a guy who loves diesels. You have to weigh the cost factor into the equation for what you are getting.
    Jester Guest
    Totally agree. A diesel swap is not a cost effective move. I will prob end up with a V8 when/if my 230 dies.
    But variety is the spice of life...
    I think the M715 is made for a diesel.
    Quote Originally Posted by saxon View Post
    Way more available, huh? Cheaper too? What are they found in?
    So, Saxon.... Think this Isuzu 3.9L would be a good swap for a CJ?
    -- Tim Taylor
  1. Body Swap vs Drive Train Swap
    By ChalkOutline in forum Modified Tech
    Last Post: April 22nd, 2010, 07:55 AM
  2. 4.0 swap
    By no1rifleman in forum Open Discussion
    Last Post: February 10th, 2010, 12:35 PM
  3. Will Isuzu dually wheels fit?
    By jpcoutts in forum Modified Tech
    Last Post: February 26th, 2008, 09:06 AM
  4. bbc swap
    By ryanroo in forum Modified Tech
    Last Post: January 3rd, 2008, 06:55 PM
