I will run through the procedure in the TM, but I wanted to run this by you guys first. My clutch does not engage until the pedal is almost completely up. Like somewhere less than two inches remaining in travel. It seems to engage fine with no slipping, but I don't like the "drive-ability" with it adjusted this way.
I assume this just means it is in need of adjustment, but is there anything else I need to be concerned about or look for while I'm doing the adjustment?
Also, when I put it in neutral and let the clutch out, there is just the faintest bit of "chatter" coming from the transmission. I'm assuming this is related to the same problem, but I'm not real versed on clutches, so I wasn't sure. Thanks!
