Results 1 to 3 of 3
Thread: Shackle flip or...
    Nov 2008
    Springtown, Texas
    Default Shackle flip or...
    I have just bought my first M715. I am used to being able to just go and buy parts and with a little fabrication be able to install them on my previous rig
    (06 wrangler X). So that in mind I have a 67 M715 and everything appears to be stock. It came from a Fire Department. First I would like to do a shackle flip on the back and Spring over on the front. Problem is i dont know where to start. Any help would be great. Also if I am starting in the wrong place on mods by all means share. This rig will be a trail rig/ sometimes street rig when I want to scare a few people.
    i know that was a mouthful but THANKS A MILLION FOR HELP
    Magilla
    A springover is a good idea if you plan on anything more than a 38" tire. 38's will rub slightly at full stuff.
    As far as little fabrication that isn't the norm for an M715.
    The shackle flip on the rear will also require you to cut the rivets and the pin where it passes through the frame on the rear front spring mount and flip it as well.
    The front will require you to weld on new spring perches, then flip the tie rods to the top of the steering arms and retaper the holes. You'll also need to trip the hole in the crossmember to allow the front driveshaft more travel downward.
    Of course new shocks, brake hoses etc are the norm too.
    Do a quick search and you'll come up with a ton of info on the subject.
    Oh and welcome to the madness!
    Jan 2008
    Montreal Canada
    look at my tread .... i'm explaining with good pictures .... this will greatly help yourself in your buildup ... shackle flip questions .... need answers asap
    Also if you want to take a look at the complete build of my m715 , you willl for sure find most of your answers throught the post. It's a canadien build M715 .... but if you dont mind ---) shackle flip questions .... need answers asap
    And good luck .... when you get bitten by the green bug ....... there's no way to fix it !!!
    Rockwells / Cummins / 3053A
    Combat wheels on 395 XML
    M104A1 trailer
  1. Shackle Flip Q
    Last Post: April 18th, 2010, 07:37 PM
  2. Spring over, Shackle Flip questions
    By scottsmyth in forum Modified Tech
    Last Post: June 23rd, 2009, 11:34 AM
  3. shackle flip questions .... need answers asap
    By Kamikaze12volts in forum Modified Tech
    Last Post: June 6th, 2008, 09:15 PM
  4. shackle flip
    Last Post: January 16th, 2008, 11:24 PM
  5. shackle flip
    By green goat in forum Modified Tech
    Last Post: July 6th, 2007, 12:57 PM
