good morning,
just thought I would ask a few questions and see if anyone has any input or advise.
I have a low mile 6.2 out of a cucv, I aquired the correct flywheel and have been kicking around the idea of swapping it into my 715.
The 715 already has the 350 conversion to the stock trans via a novak kit, the 350 is tired and needs a rebuild regardless.
this looks very straight forward except for the clutch linkage, seems the diesel engine does not have the same free / open bolt holes for the clutch pivot ball as the 350 has?? and the oil lines may interfere as they are right in the way.
Can I block off the oil lines at the block?? the truck may travel 35 miles at a time on the longest journey.
Also it seems that the stock clutch disc and preasure plate will fit up to the diesel flywheel with no problems, may have to find a new pilot bushing??
Anyway, all comments / input is greatly appreciated.
Thanks,,,
