Results 1 to 10 of 10
Thread: Hood mounted BO mods
    Default Hood mounted BO mods
    Anyone know what if a spotlight can be mounted in the hood BO light housing?
    Looks like the AM720 may have had one. I can't tell for sure, the photo is a little fuzzy.
    http://www.angelfire.com/nb2/jeeppickups/AM720.jpg
    That's a standard black out light. I have seen people modify the light to be a spot light. The light just bolts into the bracket with a single bolt so you could mount a spot light in the same hole like a big old KC off road light maybe.
    (it's late if I'm not making sense I appologize)
    Zone holster maker
    You can do a few different things with the blackout light on the hood. I converted mine to a 12V regular bulb, but retained the original housing.
    I've seen them with clear lenses too, that can fit right in the original ring. There is a GE sealed beam part that will fit, but I don't know the number offhand. A lot of small tractors used them for headlights.
    You can also do as Joe suggested and put a KC or like model light on it.
    And fire departments sometimes put a red light there too.
    There are 2 methods detailed here:
    http://www.m715zone.com/vb/view.php?...dlight_convert
    Thanks very much guys.
    Jester Guest
    I plan on using a flood lamp instead of the b/o lamp. A PAR36 worklamp is about the same size.
    Washington State
    I used a current military issue BO light from trucklite. It wasn't too expensive and looks military with a nice green led light.
    Port Orchard, Wash.
    I want to make my cargo canvas roll up like that. I've got all the clips to do it. Just need to get someone with a heavy-duty sewing machine (Al?) to help me sew them on.
    -- Tim Taylor
    Bring it on down Tim. The machine is a little dusty and could use a run or two.
    Liz, covid, murdered 10/19/21
  1. teking : How to turn a 78 J hood into a 67 M715 hood
    By teking in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 12:06 AM
  2. bed mounted gun
    By 14fan in forum Open Discussion
    Last Post: July 9th, 2009, 08:42 AM
  3. Old New Stock Hood or Wagoneer / J truck hood
    By CrashMorriss in forum Stock Tech
    Last Post: July 7th, 2009, 09:35 AM
  4. Div T-case mounted
    By saxon in forum Modified Tech
    Last Post: March 20th, 2007, 12:19 AM
