Results 1 to 10 of 12
Thread: overdrive boxes
    Default overdrive boxes
    do you know were we can get an overdrive box
    p.s. we got a sticker on ower m715 finly
    Welcome to the Zone.
    We are going to need more information however. Do you want to add Od to the stock engine, swap out drive trains, add a range box to the t-case, etc...?
    we just want to ad the od to the stock engine so we can go faster
    There really is no overdrive to put on the stock drivetrain.
    Most common methods are:
    Bigger tires...gives some relief from high rpms, but not a lot.
    Springover up front with even bigger tires...helps more...
    Ring and pinion swaps in both front and rear axles...to 4.56 gears usually.
    Change engine and transmission and use an overdrive transmission.
    Oct 2008
    Central MA
    Read: http://www.jpmagazine.com/projectbui...ect/index.html
    They used an Advance Adapters ranger torque Splitter (overdrive model)... they also had a different engine and tranny but it sounds like you could order one to fit right in to our stock setup... some fabrication most likely required.
    If you add the overdrive befor the NP200 you will have heat issues at highway speeds.
    Your best bet would be a re-gear to eliminate the heat issue in the NP200 and to give you driveability, plus still be able to wheel off-road reasonably.
    Any overdrive unit will need a fair amount of fabrication, and modification, along with new driveshafts.
    The ranger overdrive is the center section shown above betwean the bell housing and the 4-speed /w PTO.
    New Haven, CT
    Quote Originally Posted by sermis View Post
    Yup. The transfer case won't see anything different.
    If one has an overdrive AND drives no faster than before the overdrive, the tcase wont have any more problems than at present.
    If one has an overdrive AND drives faster than before, the tcase will get hotter.
  1. Overdrive tranny for the 230
    By chicklin in forum Modified Tech
    Last Post: October 22nd, 2009, 02:40 PM
  2. Heater boxes
    Last Post: October 19th, 2007, 10:45 AM
  3. Adding an Overdrive to T98
    By widlin1 in forum Modified Tech Archives
    Last Post: January 21st, 2004, 12:48 PM
