Results 1 to 9 of 9
Thread: Tranny/clutch noise
    May 2008
    Kansas City, MO
    Default Tranny/clutch noise
    I know I need to adjust my clutch pedal as it has to be nearly all the way up before it engages, but I've got another issue that may be related.
    If I put the tranny in neutral while the truck is running, it still puts a load on the motor...not enough to move the truck, but there's definitely some resistance as I can hear the motor wind down a little. By that, I mean if I push the pedal in, the noise goes away and when I let it out I hear some noise from the tranny and motor loads up.
    What could be causing this? Something with the throw-out bearing? Any way to fix this without dropping the tranny? Think it's related to the clutch pedal needing adjusted?
    1967 M715 w/w #11812
    The noise could be the throw out bearing or the input shaft for the transmission. If the engine idles down with the transmission in neutral, I lean more toward the transmission being dry or messed up bearings.
    Now, if you just started it up with the clutch pushed to the floor and have no noise. Then let the clutch out and a noise appears and the idle drops. How cold it is outside? Any time it is below around 50 or so any of my vehicles will pull the idle down until the transmission oil warms up some. The noise on mine with a 7 month old throw out bearing only happens if I haven't driven it in a week or so. Then after the first few minutes, it is gone until the truck sits a long time again.
    I would say your transmission needs to come out because it sure seems like the clutch is worn (high pedal), your throw out bearing is worn or just plain dry (noise) and you might have input shaft issues with your T-98 (excess drag.)
    That make sense?
    May 2008
    Kansas City, MO
    That make sense?
    A little, yes. I get the clutch wear/high pedal part. It doesn't slip any, although I guess it wouldn't necessarily.
    I think I get the bearing part. The input shaft is still turning in neutral, right? So the noise is just the dry bearing. Any way to lube that, or is it just replace?
    What about the engine loading up? Drag caused by the dry bearing?
    May 2008
    Kansas City, MO
    Also, yes, it does seem to be worse when it's cold or has been sitting a while.
    I used to have a CJ5 that the clutch would stick so bad that you had to start it in gear to break it free. Seemed to work fine, though. I think it made the same noise in neutral. Sounds like one of those things that, while it needs to be fixed, I can probably just run it until it gets worse.
    Quote Originally Posted by chicklin View Post
    That's correct – it might not slip but your throw-out bearing might still be riding on the clutch fingers. A high grabbing pedal can be just like a partially depressed pedal where one is riding the clutch. It should be adjusted to catch closer to the floor insuring full disengagement when at the top of pedal travel.
    Right: And so are most of the other gears in the transmission.
    #39 in the below drawing is the input shaft. The small gear on this shaft is meshed, at all times, with the large gear #73 on the countershaft - the whole countershaft spins with the input shaft. #43 and #47 mesh with the countershaft so they also spin even when in neutral.
    This slowing of the engine will happen in cold weather but yours might be dragging more than normal.
    That is exactly what I would do!!
    Hope I didn't give too much info with the drawing etc. -- just wanted to show it could be more than one bearing dragging and making noise.
    Last edited by brute4c; January 29th, 2009 at 07:54 AM. Reason: edited image link per users request
    May 2008
    Kansas City, MO
    Quote Originally Posted by amphi View Post
    Thanks for all the info, that was a great little tutorial. I confess, I understand at a high-level how a transmission works, but I've never taken time to understand the guts.
    I think I'll just adjust the pedal to compensate for the (most likely) worn clutch and then drive it 'till it breaks.
    You are welcome!!
    One more thing -- A bad throw-out bearing is most likely to act just the opposite of what you describe.
    When a properly adjusted clutch is fully disengaged the throw-out stops spinning completely because it is slid back away from the spinning pressure plate fingers. Yours might not be doing this because of the high pedal.
    Just adjust the clutch and drive it - watch for heat and listen for the noise to get worse.
    Jan 2007
    west central wisconsin
    You don't want to drive it too long making noises ,they can explode. Knew a guy who lost part of his foot when that happened. Be careful, too soon is better than too late!!!
    DJ
    Quote Originally Posted by DAVEJ View Post
    DJ
    Well that's a good point there Dave.
    Better advice than mine.
  1. Third Gear Noise
    By Pineyguy in forum Open Discussion
    Last Post: March 8th, 2009, 08:24 PM
  2. Clutch noise?
    By ralph in forum Modified Tech
    Last Post: February 22nd, 2009, 11:43 PM
  3. strange noise
    Last Post: October 1st, 2008, 11:17 AM
  4. What's that noise?
    By white433 in forum Modified Tech
    Last Post: January 13th, 2008, 07:56 PM
