OK so I'm doing the NP202 swap retaining the stock parking brake band assembly. I've read some of the threads and am running into an issue that I didn't see covered. What's happening is that when I go to put the "J" bolt through the band every thing binds up. So I did an eyeball check on the holes from the band to the retainer and they don't line up. Everything worked fine on the NP200 so I don't know what's changed. I was thinking of just enlarging a hole to make everything flow, but wasn't sure if that would work well or not. Anyone run into a problem like this?
