Meanwhile I found the number in the indicated location, when I had the engine out for an other reason. It is there, however stamping is very very poor.
Wolf
Wolf
The look and allignment of the VIN stamping makes me cringe, the 'Vehicle Identification Inspector' for my neck of the woods here in Idaho is an annoying government stickler and would balk when he saw the missaligned stamping and accuse me of stamping it myself. Its not the first time he's done that to me or my car buddies, which is why I resisted the urge to clean the area up.
When all else fails, GABFH.
I believe the technical manuals call out the location of the serial number stamps, don't they, brute? You could show the inspector the manual (or this thread, for that matter) for assurance that your number stamp is legit.
-- Tim Taylor
Here is something interesting.
I can't look at the rear frame rail because a 5th wheel setup is welded to the frame there. (Holes cut in the bed for the mounting) I sanded the front location of the frame and it is totally clean. No numbers or evidence whatsoever of stampings:
The Title lists the number 10467.
The dash has a button for a Mico Type brake hold. There is a solenoid in the rear brake line near the gas tank (which will be removed).
There is a data plate for the "Welder"
There was some kind of mechanical governor (that I removed) that had a speedometer type cable that went to the rear of the vehicle but not connected in the rear. There was a connection from the governor to the carburetor linkage.
There was no data plate on the dash board with the rest of the data plates.
So, what is it, M726 with an M715 bed on it?
Sure does seem to be adding up to that. Better watch the auction in FL so you can get a bed to match your truck.
That would be nice. But I am not in a position to do that right now. For that matter, where I am moving to will be a neighborhood that does NOT allow any vehicles sitting around. I will be keeping the M715 in the garage because I don't want the canvas to get wet and I am sure some of the neighbors would be "offended". It is a golf course community. No, I don't golf but the house was a steal and I just couldn't resist.
Here are the plates on the dash. Certainly was not originally an M715. And since the title is for 1969, the serial number (10467) doesn't fit in with the M715 series for the year 1969, more like 4/67?
Here is the massive frame attachment for the 5th wheel on the top of the frame:
And an attempt to show you the front frame. What appears to be a number is actually some welding spatter.
Does this answer it or did you already find the info? Not sure if you want to actually see in writing in the TMs...
http://www.m715zone.com/vb/showthread.php?t=12404
Sorry I wasn`t real clear. I`d like to show a inspector a manual that refers to the serial number stamp, as I am trying to get a title for a m715 with no data plate.
