Results 1 to 9 of 9
Thread: Oil Pump Rebuild Kit
    Default Oil Pump Rebuild Kit
    Does this look right? I believe the civy pump is the same?
    http://www.autozone.com/autozone/cat...estions=%5B%5D
    Looks like it....civvy pump IS the same...
    Nov 2008
    middlesex county ,CT
    230 pump has a gear and a ring. not two gears to make pressure.
    The K81C kit is the same as they list for the 232 and 258. Another mislabeled Jeep Tornado part.
    But it has to fit. The computer says so........
    Default 232
    Quote Originally Posted by Warthog View Post
    Yes, it does say so! Strange how ALL the auto parts suppliers have the same errors. There must be a service that supplies the part numbers to everyone, therefore, everyone is wrong.
    The proper kit would be a K-76 which is no longer available but it looks like the pump is, M-76, from Melling.
    Amazing what you have to learn, the hard way, but at least you can do lots of research with the internet. Now, if we can just get someone to answer the phone at these companies that speaks english.. . . .
    Default Has Anyone Tried This?
    Melling, the manufacturer, says they still have a few M-76 oil pumps for the 230. Can anyone confirm they really fit?
    SF Bay Area, CA
    That number sounds correct. It's a cast iron pump that fits the Military 230. Original oil pump was aluminum. with steel gear/rotor
    SF Bay Area, CA
    I looked through my records, and yes, M-76 is the correct p/n for the Melling pump.
  1. Fuel/Vaccum Pump Rebuild
    By rboltz in forum Stock Tech
    Last Post: November 19th, 2008, 02:09 PM
  2. Fuel pump rebuild
    By gregolma715 in forum Stock Tech
    Last Post: July 7th, 2008, 12:52 PM
  3. Top end rebuild
    By vacca rabite in forum Stock Tech
    Last Post: May 28th, 2008, 11:14 PM
  4. fuel pump doesn't pump.
    By sf38a1 in forum Stock Tech
    Last Post: April 11th, 2008, 08:58 PM
  5. Fuel Pump rebuild Hints
    By Bean101 in forum Stock Tech Archives
    Last Post: April 7th, 2004, 04:54 AM
