The carrier is the thing inside the axle that the ring gear bolts to...and the spider gears are in.
I have never seen a lower numerical ratio carrier...I would assume you would have to reuse the stock spider gears as the M715's 23 spline axles would dictate that.
I dont know an application to give you either...but I do know the ones with anti lock brakes are out as they have a different offset to the ring gear...and some of the units without anti lock have a different offset...
Maybe Randys could help there too.
With 4.56 gears, if you left stock tires on the truck, it would give the same rpm reduction as going to 44.5 inch tires would...thats a big drop...4.10, if you can find the stuf, would be as far as I would drop the ratio numerically...
The Detroit locker will fit in a stock carrier as it is 2 piece.
