Results 1 to 9 of 9
Thread: Brake flex hoses
    Question Brake flex hoses
    I am getting the brakes working this week but i am going to need rubber hoses front and rear. Are these going to be surplus only or is there a conversion for this too. I have already done the E350 wheel cylinders and #60 shoes.
    US ARMY
    Besides NOs lines that are 40 plus years old and of dubious condition now, the only thing I know that is out there is VPW had the front lines...maybe the rear too...reproduced...new production. The quality is good but they differ a bit from stock. NO mods are needed to mount them, they will go on any stock truck with stock wheel cylinder OR the Ford E350 wheel cylinders...no sweat...the metal lines toward the ends are a little diferent but they will work like stock.
    Mar 2004
    northern Arizona
    has anyone carried one into a NAPA and checked for a comparable one? I don't have any apart at this time, or I would.
    There's got to be aftermarket available that would work.
    67 M725 67 M715 68 M715
    Jan 2007
    East Tennessee
    I put new flex hoses front and rear on mine. I took the old hoses to Royal Brass and Hose and they simply made new hoses to match (length and fittings). I did opt to go with overmolded braided hose since I wasn't too concerned about keeping the hoses stock. If I remember correctly, the cost for the three hoses was less than $60 2 years ago and they made them while I waited. They are a chain, so you can look them up online and see if one is near you, or find another local supplier of hydraulic lines. I am pretty sure all those places will have a variety of fittings in stock and the make to order.
    Quote Originally Posted by compexp View Post
    Last year when I was doing my brakes I looked thru the NAPA catalogs and could not find any thing close for the fronts. I did find one for the rear but it didn't have the outside spring guard. NAPA UP5784
    Jan 2007
    Fort Smith, Arkansas
    After reading the last two replies, I'm curious if the spring guard could be installed on a new hose before the fittings were swaged on. Could it be removed from the old hose by cutting the end off? I don't recall exactly how it is attached to the hose.
    Quote Originally Posted by Warthog View Post
    Are you sure on the part number? I tried and there was no listing. Maybe I should be less lazy and look it up.
    US ARMY
    Put a space between the UP and the number.
    http://www.napaonline.com/NOLPPSE/(S...Dn=0&Dk=1&Dp=3
    Thank you that is much better.
    US ARMY
  1. Brake hoses
    By ian67m725 in forum Stock Tech
    Last Post: December 22nd, 2010, 01:50 AM
  2. Custom Length Brake Hoses
    Last Post: June 8th, 2009, 08:49 PM
  3. Brake Flex-lines
    By fng in forum Modified Tech
    Last Post: February 28th, 2009, 07:15 PM
  4. Rubber (or flex) brake lines?
    Last Post: June 6th, 2008, 11:41 AM
  5. Less springs more flex
    By 5quarter in forum Modified Tech
    Last Post: May 31st, 2008, 08:43 AM
