what are you boys using for body mounts? i don't like the way the factory mounted it with those wimpy rubber donuts, springs & only 3/8' bolts. i was thinking of turning me some donuts out of some nylon round stock & raising the cab up about an inch or a little less. my truck has had a problem in the past of the radiator bottom tank rubbing the diagonal frame supports underneath, & i don't want that problem again. what do you think? thanks!
andy
