Results 1 to 10 of 14
Thread: Stock Fuel Filler hose
    Feb 2009
    Huntington Beach, CA
    Default Stock Fuel Filler hose
    does anyone know where i might be able to buy the rubber fuel filler tube, the piece from the gas tank to the metal filler. i don't mind paying the price. i just cant find one anywhere.....
    Memphis Equipment had a run of these made recently...they are pricey...in the $100 area...but they are correct in size/fit and are new pieces that dont crack and leak in a year or 2 like NOS ones do.
    Contact info:
    http://www.memphisequipment.com/
    Main Office:
    766 South Third St.
    Memphis, TN 38106
    Ph: 901-774-0600
    Fax: 901-946-1919
    sometimes you see one on Ebay...none there this minute...
    Feb 2009
    killer,
    thanks for the info.
    Nearly two years on my fuel filler hose and it still looks like the day I installed it. Got it from Memphis Equipment.
    Default Stock Fuel Filler Hose
    I'm about to replace my old fuel filler hose and wondered if anyone has any hints to an easy installation.I bought a new one some time ago from AB Linn on ebay.i'M assuming it may have shrunk over time and could be a bear to put on.My thoughts are sofar to clean up the tank inlet and filler end with emery cloth apply some low heat (hair dryer) to the hose ends then smear some hand cleaner (non pumice type) to both ends and install the filler cap end first,then through the body hole and on to the tank inlet.I do know to cover the tank inlet prior to cleaning to keep crud from getting in the tank. That's what I think-What did you do ?. Thoughts and suggestions welcome.By the way I'm 68 years old and still don't everything.Regards Joe
    Jun 2009
    Mt. Prospect, Illinois 60056
    Put it in boiling water for a few minutes, it will soften the rubber and make it more pliable. Worked for me. I just saw someone on the Zone with a couple of necks for sale. If it's not to late, check in the for-sale ad. Good luck.
    Jan 2011
    Fernandina Beach, FL
    I had no problem with installing a new rubber filler neck. I used silicone spray both on the neck interior and the male surfaces of the fill tube and the tank. Mind you, it is in the 90s here so the rubber is soft...
    One is on Ebay now from Memphis Equipment.
    http://cgi.ebay.com/ebaymotors/Fuel-...item45fbf77513
    1968 M725(2)
    1967 M715
    1967 M725(2)
    1963 M43
    1954 M37
    1967 M103A3 w/M1010 Body
    Jan 2011
    Quote Originally Posted by moose3d View Post
    I got one of those hoses from Memphis and it worked just fine. Not too difficult to install. I used silicone spray and it was summer time, warm. Good quality. I was pleased with it.
    Boyce Equipment has them too. I'll be picking up a new one for my truck next week
  1. Engine Compartment Flexable fuel Line (Fuel Hose)
    By BlessedM715 in forum Stock Tech
    Last Post: January 3rd, 2010, 01:47 PM
  2. Fuel filler unit
    By Chumley in forum Stock Tech
    Last Post: May 21st, 2009, 05:02 PM
  3. Fuel filler neck
    By Kamikaze12volts in forum Open Discussion
    Last Post: March 27th, 2008, 09:32 PM
  4. fuel filler hose
    By george walker in forum Open Discussion
    Last Post: July 24th, 2007, 09:15 PM
  5. Gas tank filler hose?
    By Calpyro in forum Open Discussion
    Last Post: June 17th, 2007, 09:04 PM
