Results 1 to 10 of 17
Thread: Transfer Case Woes
    Jester Guest
    Thumbs down Transfer Case Woes
    Got the case out without too much fuss. Took me about an hour to scrape off 5 lbs of oily mud. Need to clean it up more before I open it up. Don't want all that stuff inside the case. Will clean it tomorrow.
    Prob should order up a gasket kit too.
    More to come...
    Jester Guest
    Poor little scuzzy t-case.
    Looks pretty good so far.
    What would be the minimum to pull and then be able to move the linkage? Trying to figure if there is a way to look for the trouble before a complete gutting of the case...
    Jester Guest
    O yeah, she's broke. The thrust washer (p/n 7994044) is broken. Don't ask me how. Guess I need a rebuild. Insert curse word here.
    That is not pretty...bummer...sorry to see that.
    Jester Guest
    As another 'zoner told me tonight, better that it happened in my drive than out on a trail. Yeah, it sucks BUT at least I will have a fresh 'case now - just trying to make some lemonade here.
    Hey Brandon, want to use my case as the guinea pig for a 200/205 hybrid?
    Georgetown, CA
    Interesting, . probably just shifted things enough when you were pulling the yokes to do the seals to shake the parts loose, . ..How did the gears look? This might have been a blessing in disguise in more than one way. Of course it is better found in driveway than on trail, but also if gears are okay, it happening now might have saved much bigger problem when it spit parts into gears. I had a spicer 18 case come apart in my CJ while driving down the road, fortunately about a 1/4 mile from my house in a 25 zone, but it locked up the case tight, . .destroyed 1/2 the gears,. . .had to take drive lines out to tow it home. . ..
    Jester Guest
    Quote Originally Posted by moosejr View Post
    How did the gears look? .
    All the gears look fine as far as I can tell.
    Silver lining...yeah, much better it happened at home...these things arent the cheapest to have towed from the middle of nowhere...
    Hopefully it is a straight forward rebuild...were you thinking of trying the 205 guts in the 200 case?
    Jester Guest
    Gonna talk with Brandon about it. I am willing to be the test case.
  1. transfer case ?
    By d4colombo in forum Modified Tech
    Last Post: September 11th, 2012, 10:01 AM
  2. ron : NP{200 Transfer Case
    Last Post: November 11th, 2009, 06:04 AM
  3. Replies: 10
    Last Post: November 29th, 2008, 08:33 PM
  4. Flipped 208 transfer case
    By tonka in forum Modified Tech
    Last Post: July 11th, 2008, 04:19 PM
