Results 1 to 9 of 9
Thread: bed mounted gun
    Default bed mounted gun
    Does anyone have any pictures of the mounting for a bed mounted 30 cal. I am at that stage and not sure what would be the best way.Thanks
    Dustin
    Beast has a .50 I believe...couple pics here:
    http://www.i2k.com/~schwarzd/m715a.htm
    Feb 2004
    Silver Lake Sand Dunes MI
    Here are a few better pics of mine. I used a plate at the bottom, one at the top of the bed rail, and two support legs.
    Dave
    Springdale, Arkansas
    That won't really stand up to sustained firing will it? That's just for dispaly, right?
    Sustained firing? Are you invading someone?
    fending off the zombies.
    Yep, that's right. Stinkin' zombies....
    Just looking at other mount's and applications, they look to be bigger diameter and more substantial. And hey, even firing a 1919a4 semi-automatic can produce quite a bit of stress.
    We actually warped an airframe once using M2's mounted to a Blackhawk during testing. But that's another story for another day.
    this will be for show only, except for the occasional moose or brown bear. Thanks for the pics, thats the way I think i will go.
    How about a ring mount? You could probably use the hardware from a deuce mount back there and place the legs against the bed sides so as not to lose any floor space. This way you won't have to worry about zombies sneaking up your backside
  1. maddawg308 : What was mounted here?
    Last Post: November 12th, 2009, 02:01 AM
  2. Hood mounted BO mods
    By gargemel_622 in forum Open Discussion
    Last Post: January 15th, 2009, 01:11 PM
  3. XL's Mounted
    Last Post: December 2nd, 2008, 11:16 PM
  4. Les Schwab Mounted my New Tires/Wheels
    Last Post: September 29th, 2007, 01:15 PM
  5. Div T-case mounted
    By saxon in forum Modified Tech
    Last Post: March 20th, 2007, 12:19 AM
