Results 1 to 8 of 8
Thread: hub nut, lock washer, and seal question.
    rottiedogs Guest
    Default hub nut, lock washer, and seal question.
    Some new parts showed up today. Went to install the front manual hubs and decided to lube the wheel bearings while I was in there. First side came apart quick but there were no lock washers. No tabs were locking the nut and there was not tang engaging the hub..... Not going to drive until I check all wheels. Also, the inner seal was missing some chunks.
    Question, I searched but couldn't find any part numbers for the seal or the lock washers. Any cross out there for napa part numbers?
    thanks,
    Mike
    I have this from an old post on the old Yahoo board...
    Front Axle:
    1.) Inner Bearing Oil/Grease Seal (National # 475384 x 54); 2.)
    Complete Knuckle Gasket/Seal Kit (Spicer #706230X) which includes 12 x rear oil seal bolts, 2 x outer metal seal, felt gasket, rubber seal, and metal ring seal.
    rottiedogs Guest
    Got some spindle lock nuts for a jeep gladiator. They are too small....
    Looks like the truck stays on jackstands for a little longer.
    I would think that dana 60 spindle size would be consistant but doesn't appear to be true.
    I did some searching and saw a post that said that an early ford F350 had the same spindle. Can anybody confirm this? Same spindle lock nut and washer size?
    rottiedogs Guest
    Found a part at autozone that might work. Seems to be the correct dimensions:
    Part Number: 618-046
    Weight: 0.16 lbs
    Warranty: 3 MO
    Application: 4500 lb axle (Located on driver's door jamb)
    Notes: AutoGrade (boxed) Washer - Front
    Type: 10
    Inside Diameter: 2 in.-1/16 in.
    Outside Diameter: 2-9/16 in.
    Thickness: 5/64 in.
    Keyway Tab: 1/8 in. x 1/4 in.
    What do you think?
    Mike
    rottiedogs Guest
    Just in case anybody else is looking for these parts, found a place. Got the parts and they fit!! I ordered spares @ http://quad4x4.com/
    Qty. Product No. Product Price ea Total
    1 QU40051-2 Flat Spindle Washer Set 9.98 9.98
    1 QK4730 Hex Spindle Nut Kit for 2'' threads 20.97 20.97
    Great post...THANKS!!
    rottiedogs Guest
    Your welcome. Main reason I posted was because I spent 20 at Napa and the parts didn't fit and it wasted a week.
    And I know it will help others now!
  1. Rear Main Seal Question
    By drose5432 in forum Open Discussion
    Last Post: February 25th, 2009, 03:03 AM
  2. rear main seal question
    By Duane in forum Stock Tech
    Last Post: December 13th, 2008, 04:29 PM
  3. Washer behind pintle?
    By KsM715 in forum Stock Tech
    Last Post: December 12th, 2008, 07:43 PM
  4. Winch Lever Lock question
    By Roger1952 in forum Stock Tech
    Last Post: January 29th, 2008, 07:26 PM
