Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: 715 headlight problems
    Breaker tripping means change switch...just going to LED lights might temporarily stop or mask the problem...but it needs a new switch...last thing you want is the dreaded wiring fire...a whole new harness is a much bigger job than a new switch...
    New Haven, CT
    If one goes from 24V to 12V, you are doubling the current through the switch.
    Correct...and an even better reason to change it!
  1. 7 Round H4 Headlight Conversion
    By Tomahawk715 in forum Modified Tech
    Last Post: December 10th, 2009, 11:28 PM
  2. Headlight springs
    By Chumley in forum Stock Tech
    Last Post: August 20th, 2008, 09:02 PM
  3. Headlight switch breaker?
    By the1968jeepthing in forum Stock Tech
    Last Post: November 3rd, 2007, 04:13 PM
  4. multifunction headlight switch
    Last Post: June 13th, 2007, 09:46 PM
