Results 1 to 10 of 12
Thread: foreverunstopable : Air Filter, Old Style
    Default foreverunstopable : Air Filter, Old Style
    Post by foreverunstopable on Apr 22, 2006, 4:24pm
    Hey guys. I'm not sure if this is new news or not. I looked up the old parts list and didnt see it in there. We dont have many Napa's down here to get the GOLD 2050 which in my opinion didnt sit very well as the previous owner had one installed. I stopped in Advance Auto and basically opened ever air filter they had. A Purolator A30057 seems to be a "perfect" fit. It seals well, just fits in, and is easier for me to ger replacements of. Hope this helps out.
    Default brute4c :
    Re: Air Filter, Old Style
    Post by brute4c on Apr 23, 2006, 8:24pm
    NICE!!
    One question, does it have the extended rubber flange on the one end to seal to the can? Seems someone posted a part number with the flange some time back...
    Post by foreverunstopable on Apr 25, 2006, 8:54am
    I would say yes as its a perfect seal with the compression of the top clips
    Default brute4c :
    Post by brute4c on Apr 25, 2006, 9:26am
    If you look at this image, you can see that the upper part of the stock aircleaner has quite an overhanging lip or flange on it...does the one you found have this? For those who are sticklers for the stock parts, this is important.
    Port Orchard, Wash.
    Default binfordm715 :
    Post by binfordm715 on Apr 25, 2006, 9:32am
    But I'm a stickler for off-the-shelf parts that are affordable, yet do the job properly. Would the extended top seal make a difference if the top pulls down tight against the gasket? Just wondering is all. I can't see a downside if it's tight, but I may be overlooking some aspect. What do you think?
    Default brute4c :
    Post by brute4c on Apr 25, 2006, 10:05am
    I would think it would seal if the top of the filter is in good contact with the lid when closed...light amount of grease on the top of the filter, then assemble, remove, and see if the grease transferred...if it isnt obvious anyway...
    The rubber flange is basically the watertight seal for fording...not an air seal per se...
    Default amphi :
    Post by amphi on Apr 25, 2006, 10:13am
    The fire department where I got my M715 gave me a list of Wix filter numbers. I purchased this one and it doesn’t have the lip but seemed to seal just fine.
    FYI:
    Air Filter : Wix 42050
    http://www.wixfilters.com/filterlook...p?PartNo=42050
    Default brute4c :
    Post by brute4c on Apr 25, 2006, 10:15am
    That is essentially the same as the Napa Gold 2050 listed in the first post of the thread that he said didnt fit to well in his application...
    Default amphi :
    Post by amphi on Apr 25, 2006, 10:29am
    Now I can see where it could draw air or water without the lip to seal it off. I agree it is ok for air because it will still go thru the filter.
    I also agree with Tim’s off-the-shelf parts --- cheaper is ALWAYS better.
    The Purolator A30057 crosses to a Wix 42055 not the 42050 I installed. Maybe I’ll try the 42055 next time but mine seem to fit ok.
    SF Bay Area, CA
    Default hiker :
    Post by hiker on Apr 25, 2006, 12:46pm
    For everyday use, I carefully cut that extra rubber flange lip off a used stock filter to use as a gasket with the NAPA filter to provide sealing of the lid.
    Robert
  1. foreverunstopable : XL Tubes and Flap
    Last Post: November 12th, 2009, 03:50 AM
  2. foreverunstopable : Lav Weight
    Last Post: November 12th, 2009, 01:38 AM
  3. foreverunstopable : XL spring-over picture
    Last Post: November 12th, 2009, 01:32 AM
  4. foreverunstopable : Anyone have boots?
    Last Post: November 12th, 2009, 01:17 AM
  5. foreverunstopable : Steering Problem
    Last Post: November 10th, 2009, 11:39 PM
