Results 1 to 9 of 9
Thread: dxeflyr : Bed tie downs
    Default dxeflyr : Bed tie downs
    Bed tie downs
    Post by dxeflyr on May 1, 2006, 4:21pm
    The previous owner cut the corner eyes off the top of the bed of my truck... do these play any part in holding the cargo cover on? I am going to eventually put the cover back on and wondered if I should start scrounging up some new eyes to weld back on. Thanks!
    May 2004
    Anchorage, Alaska
    Default 40grit :
    Re: Bed tie downs
    Post by 40grit on May 1, 2006, 6:54pm
    me thinks they are for lifting the bed off, mine are "trimmed" too
    Default brute4c :
    Re: Bed tie downs
    Post by brute4c on May 1, 2006, 7:44pm
    They are not part of the cargo cover...
    They are for lifting the bed...but if you dont use some kind of side support and just try to hook up to those points and lift, they will get bent up..
    Port Orchard, Wash.
    Default binfordm715 :
    Re: Bed tie downs
    Post by binfordm715 on May 1, 2006, 11:32pm
    ....no, bent in!
    Sorry, couldn't help myself....
    Default elwenil :
    Re: Bed tie downs
    Post by elwenil on May 2, 2006, 7:23am
    They are also used to tie down a S-250 shelter if one is placed in the back.
    Default brute4c :
    Re: Bed tie downs
    Post by brute4c on May 2, 2006, 8:56am
    Good point, yes they are...heres pics of a nice install...
    http://www.m715zone.com/galleries/me...hilg/phil.html
    Default robertcowan :
    Re: Bed tie downs
    Post by robertcowan on May 2, 2006, 10:54am
    HUMMM makeum good camper huh ? like to find one of those.
    bob
    Default barrman :
    Re: Bed tie downs
    Post by barrman on May 2, 2006, 12:14pm
    I don't have the picture here at work, but I used a full size CAD drawing Chris posted some time ago to make 4 new ones out of 1/4" steel. I use them to tie down round bales of hay and other stuff I haul around. Besides being elbow magnets, they work great for what I use them for.
    Washington State
    Default fisherman :
    Re: Bed tie downs
    Post by fisherman on May 2, 2006, 1:26pm
    Actually I think it is 3/16" material, two of mine were cut off, I made four new ones and added two above the wheels, in the middle of the bed. I liked them so much I thought a couple more couldn't hurt. We used a large punch to make the holes, and cut and ground until almost perfect shape. No one will know after the bed coating is installed. Fisherman
  1. dxeflyr : Tailgate hardware?
    Last Post: November 12th, 2009, 05:01 AM
  2. dxeflyr : T-case oil
    Last Post: November 12th, 2009, 01:43 AM
  3. dxeflyr : U-joint question
    Last Post: November 11th, 2009, 05:11 AM
  4. dxeflyr : Jerry cans
    Last Post: November 11th, 2009, 03:46 AM
  5. dxeflyr : Need electrical help, again...
    Last Post: November 11th, 2009, 12:10 AM
