Results 1 to 10 of 12
Thread: davenjeip : Door Hinges
    Default davenjeip : Door Hinges
    Door Hinges
    Post by davenjeip on Jun 2, 2006, 5:54pm
    The drivers side door hinges on my truck are tweaked and need replaced.
    If I understand correctly, any FSJ hinges will work but they do not open as far as the 715 ones do. I can pick up a set from a full size locally for $20, but wasn't sure if that's what I wanted to do.
    How big of a difference is there in the amount the doors will open?
    Are there any good sources to purchase stock hinges?
    Default tacomainoh :
    Re: Door Hinges
    Post by tacomainoh on Jun 2, 2006, 6:38pm
    There are no sources for new hinges. FSJ doors open pretty dang far... not sure how much of a difference there is, or if it matters much.... I'll have to compare the two when I get home.....
    I'd just get the FSJ hinges. It might be a difference of like 90* for the stock hinges vs 85* for the FSJ hinges LOL They really do open pretty far.
    Re: Door Hinges
    Post by brute4c on Jun 2, 2006, 7:13pm
    I think the older, pre74 FSJ hinges are the same or real close and the later are lesser in the degree department...though its not a huge difference or a restrictive one...
    Northern Colorado
    Default fsjguy :
    Re: Door Hinges
    Post by fsjguy on Jun 2, 2006, 10:48pm
    Jon, you're correct. The older ones will go pretty close to 90 degrees. Check out my website and look at my civvy door installation. IIRC, there's a pic of the door hinge difference. It was changed when they added power windows. The old style hinge doesn't seem to have enough room for all the wires to get past it.
    Here's a direct link:
    http://www.bigscaryjeep.com/civil/civil.html
    Scroll down and you'll see the two hinges opened up side by side.
    Also, it helps to have a second person when hanging a door. Not required, but it makes life easier, and isn't that what it's all about?
    Re: Door Hinges
    Post by tacomainoh on Jun 2, 2006, 11:42pm
    Ditto on the helper for hanging them. The doors are... cumbersome.
    Re: Door Hinges
    Post by brute4c on Jun 3, 2006, 8:12am
    Thanks fsjguy!! I knew someone would know for sure...I probably got most of my info from your page and the junkyard crawling I do...
    Default thetroublemaster :
    Re: Door Hinges
    Post by thetroublemaster on Jun 3, 2006, 8:15am
    My 69 wagoneer doors open just as far as my M715. FWIW...
    Default davenjeip :
    Re: Door Hinges
    Post by davenjeip on Jun 3, 2006, 2:21pm
    Thanks for the help.
    I just picked up the truck and the guy threw in a FSJ door with the truck and it still has the hinges mounted on it. After a quick comparison they look to be identical.
    The door is bent up a little more than I had realized, so I don't know if it'll be worth saving. I figure that I'll swap over the hinges and get an idea of how it's working before I decide what to do.
    For no good reason, I'd like to keep the original door but it may not be worth the effort. Either way, it looks like I should be able to make something work without too much trouble.
    Silver Lake Sand Dunes MI
    Default beast :
    Re: Door Hinges
    Post by beast on Jun 3, 2006, 2:59pm
    FSJ hinges changed in 1980. Any 79' or older hinges will open the full 90 compaired to the newer ones.
    Northern Colorado
    Default fsjguy :
    Re: Door Hinges
    Post by fsjguy on Jun 4, 2006, 1:30am
    If you have a good civvy door and you looked at my link, you already know what to do with that civvy FSJ door.
  1. gaskets under door handles, door panel clips, widow clip
    By Mudkaiser in forum Modified Tech
    Last Post: February 17th, 2024, 10:33 PM
  2. davenjeip : Battery Mount
    Last Post: November 11th, 2009, 03:54 AM
  3. hood hinges?
    By res0wc18 in forum Stock Tech
    Last Post: July 6th, 2009, 03:38 PM
  4. Door gaps?
    By Angry_Truck in forum Open Discussion
    Last Post: October 24th, 2008, 12:44 AM
