Re: Transfer case pictures
Post by kwai on Jun 24, 2006, 8:52pm
10-bolt pto cover would seem to make it a np202. Maybe Barrman or Bob Cowan can say for sure since they Bob has the NP202 that Barrman sold him.
Post by tacomainoh on Jun 24, 2006, 10:24pm
I think that's a 202.
Post by robertcowan on Jun 24, 2006, 10:51pm
yep its the identicle t-case i got from BARRMAN. its installed in a m715 now. i,ll post pix asap. fisherman did you get the top mount crossmember with it ? also the last year these were made is 1964 i found out. i found a perfect set of poly mounts to use with this t-case as the originals are made anymore.
bob
Post by fisherman on Jun 24, 2006, 10:56pm
Thanks Bob, I wonder why it was used in a 1970 truck?. I need to know what to do to add the e brake setup. Yes I do have the top crossmember mount. And I would like to know about the poly mounts. PM me or I'll give you a call if it is ok. Fisherman
Post by robertcowan on Jun 24, 2006, 10:58pm
i,ve got another t-case thats going in a m715 with rockwells. it came with 1410 u-joints from the factory and the shafts are 1/4" bigger in dia. than the np200, np202 and np205. this is a hulkin- t-case. i,ll post pix of it in the near future.
bob
Post by fisherman on Jun 24, 2006, 11:04pm
Bob, you were able to bolt on the e-brake setup off the 200? And you used the clamshell style top mount? Fisherman
Post by tacomainoh on Jun 24, 2006, 11:09pm
Bob, where did you get that information? Six States told me they were up to the early 70's? and I find it difficult to understand why they would make basically a bigger 205, then go back to the 200 and mess up the model numbering... and then reinvent the 205.
Post by binfordm715 on Jun 25, 2006, 1:28am
According to my "Standard Catalog of 4x4's: 1945-1993," Fisherman's donor vehicle, a 1970 International Series 1100D pickup, only had one t'case offered by the factory and it is listed as a TC-141 with ratios of 1.93:1 and 1.00:1.
Does this make sense to anyone?
Edit: I love Google! Right off the bat, I answer my own question:
This from http://hometown.aol.com/eldonmcf/tcase.html
Transfer Cases used for other IH vehicles are:
TC-140, CODE 13140 = NEW PROCESS MODEL unknown
The TC-140 appears to be a pre 1960's model, and could be either a model 200, or 201.
The part number for the TC-140 transfer case assembly 148970R91 is replaced by 227639R91 which is the assembly number for the TC-141, NP 202 transfer case.
TC-141, CODE 13141 = NEW PROCESS MODEL 202
TC-142, CODE 13142 = NEW PROCESS MODEL 205
Post by bigwheelbob on Jun 25, 2006, 7:49am
This is a 202 transfer case, uses the standard 2.125 seal, 410308 national if I remember right. From what I can tell this one came in right after the 201, which still had the break, but had a center rear output One way I remember is the top bolts come thru the case into the oil, so you need to use sealer on them. The case LuckyPabst posted is a 201 which has a rear bearing retainer all its own. Also, Bob cowan, I do have a couple factory crossmembers for these cases, call me if you need one.
