Results 1 to 5 of 5
Thread: dj : Windows
    Default dj : Windows
    Windows
    Post by dj on Jun 23, 2006, 10:54pm
    I finally had a few minutes to spend looking my newly acquired 715. (kid is building a house,takes most all my spare time). Anyway when the top is off and the windshield down and the big windows rolled down, what happens to the small windows ? Can they be easily removed?
    Thanks DJ
    Default texan :
    Re: Windows
    Post by texan on Jun 23, 2006, 10:59pm
    They come out pretty easily, 2-3 bolts, I believe. You can see them on the inner door panel, and maybe one on the front part of the door, hidden when closed. I can check in the morning.
    Don
    Default jeepistdougiowa :
    Re: Windows
    Post by jeepistdougiowa on Jun 23, 2006, 11:00pm
    Screw from inside the door jam, and one through a hole in the door panel. IIRC, a #3 phillips bit in a 1/4 socket makes this job easier than using a stubby screw driver.
    Default kwai :
    Re: Windows
    Post by kwai on Jun 23, 2006, 11:06pm
    The windows can be stowed behind the seats and secured using straps through the footman loops.
    Default brute4c :
    Re: Windows
    Post by brute4c on Jun 24, 2006, 9:27am
    Illustrations 15, 17, and 18 in the -10 Operators Manual show the location of the window mounting and where they stow.
  1. Tips for greasing stiff windows
    By randygar in forum Stock Tech
    Last Post: December 5th, 2009, 04:42 PM
  2. 725 Power Windows
    By alosix in forum Modified Tech
    Last Post: May 29th, 2007, 01:27 PM
