Results 1 to 10 of 10
Thread: canders7 : Bridge plates. . .what numbers for my rig?
    Default canders7 : Bridge plates. . .what numbers for my rig?
    Post by canders7 on Jul 17, 2006, 5:21pm
    So I don't have an M715 but I do have a FSJ Cherokee that I am trying to make into a "military" vehicle. Afterall the army did use K5 Blazers. What numbers would be used on the bridge plate in my situation.
    Thanks for understanding that I don't actually have the real thing, I would if I could find one and talk the wife into another Jeep!
    Default binfordm715 :
    Re: Bridge plates. . .what numbers for my rig?
    Post by binfordm715 on Jul 17, 2006, 5:28pm
    C
    04
    Default canders7 :
    Post by canders7 on Jul 17, 2006, 9:38pm
    Thanks Tim.
    Post by binfordm715 on Jul 18, 2006, 12:09am
    Just for my own edukation, would a CUCV be C-04 too, guys?
    Default elwenil :
    Post by elwenil on Jul 18, 2006, 7:25am
    Note, the "C" is for "Combination Vehicle", or in simplier terms, one towing a trailer. If you are not towing something, the "C" should be turned around backwards. Check out the Quirks Manual in the Online Manuals section for more info.
    Post by binfordm715 on Jul 18, 2006, 9:49am
    Quirks booklet says the "C" is for "loaded, cross-country" and the "05" is used when pulling a trailer. "04" used otherwise. But nothing about the "C" not being used.
    Default elwenil :
    Post by elwenil on Jul 18, 2006, 10:06am
    The Quirks manual isn't real clear on that point. Here is a tech artical from the military over at Steel soldiers that give more info on the Bridge Plate and the "C":
    http://www.steelsoldiers.com/index.php?s....view _photo.php
    As usual you will have to copy and paste the link and delete the space. Click on the image for a bigger version that is easier to read.
    Default tacomainoh :
    Post by tacomainoh on Jul 18, 2006, 11:35am
    Tim, my CUCV bridge plates have no "C"
    Default k8icu :
    Post by k8icu on Jul 18, 2006, 8:54pm
    Yes on the 04 for CUCVs
    Post by brute4c on Jul 19, 2006, 8:28am
    Possible...On the flat piece that holds all the numbers in at the top of the bridge placard, the C may be on the rear and you didnt notice? Also possible that the C is gone or nearly gone...mine has whats left of a red C...very faint now and needs redone...
  1. canders7 : Question about tires 11.00-16?
    Last Post: November 11th, 2009, 05:19 AM
  2. canders7 : Radius of wheel well openings for M715?
    Last Post: November 11th, 2009, 05:06 AM
  3. canders7 : M101 Trailer coupler question?
    Last Post: November 11th, 2009, 04:57 AM
  4. More bridge plate Q
    By pghjeeper in forum Stock Tech
    Last Post: April 29th, 2008, 09:48 AM
  5. Bridge Plates
    By Mot-Man-616 in forum Open Discussion
    Last Post: July 21st, 2007, 12:08 AM
