Results 1 to 7 of 7
Thread: buggles911 : axle u joint fluid
    Default buggles911 : axle u joint fluid
    axle u joint fluid
    Post by buggles911 on Jul 26, 2006, 7:32am
    Hello,
    I just purchased my first M 715 and I am thrilled!!!!
    I spent a lot of time looking and finally found what I was looking for. I spent a lot of time here on the zone reading everything and I have to say thank you to everyone who made this place what it is. I know more now about my M 715 than I do about my girlfriend!! I do have one question concerning my axle u joint fluid. I read all the tech. manuals and still have no idea how to drain them and what fluid to use? I found the fill plugs and these are the last fluids I need to change. I would appreciate any help with this. As soon as I have a little more time I will post the full bio of the vehicle and post some pictures.
    Default jeepcj :
    Re: axle u joint fluid
    Post by jeepcj on Jul 26, 2006, 8:20am
    Do you mean axle or U joints? Ujoints use grease. the axles use 90 wieght oil
    Default warwick :
    Post by warwick on Jul 26, 2006, 10:29am
    some use gear oil, others use a mix of gear oil and grease. i would push as much grease as you can get in knuckle. to clean out the old grease its a little involved, pulling the hub and spindle, but not to difficult. check the online manuals for the steps involved.
    ETA: unless your seal is bad i would just fill it, and clean it the next time you pull your hubs/brakes apart.
    Post by brute4c on Jul 26, 2006, 3:54pm
    Yep, the military closed knuckles use grease...just like one would use for the Ujoints in the driveshafts...
    Post by buggles911 on Jul 26, 2006, 8:13pm
    I pulled the fill plugs and they were packed full of grease. Misunderstood lube order "B-30". I didn't think the knuckles were full of gear oil, but wanted to be sure. Any recommendations on grease grade and how not to cover myself from head to toe when changing? Thank you
    Washington State
    Default fisherman :
    Post by fisherman on Jul 26, 2006, 9:46pm
    I used Lucas Red Grease, filled knuckles with the grease gun til they were full. Use latex gloves for cleaning or degreasing , then throw them away and grab another pair. A box is only about 8 or 10 bucks.
    Default jeepistdougiowa :
    Post by jeepistdougiowa on Jul 26, 2006, 9:57pm
    Don't get ridiculously carried away, you'll put unecessary drag on the drive train...I think it was brian who had grease shoved 1/2 way down the axle shafts.
  1. Which DOT of Brake Fluid???
    By SAC715 in forum Stock Tech
    Last Post: July 5th, 2009, 05:45 PM
  2. Brake Fluid
    Last Post: April 26th, 2009, 10:32 AM
  3. Tranny fluid
    Last Post: March 11th, 2009, 08:17 AM
  4. DOT3 Brake Fluid
    By rboltz in forum Modified Tech
    Last Post: February 21st, 2009, 10:59 AM
  5. fluid change
    Last Post: March 23rd, 2007, 03:08 PM
