Results 1 to 2 of 2
Thread: fisherman : Brake line routing.
    Washington State
    Default fisherman : Brake line routing.
    Brake line routing.
    Post by fisherman on Aug 7, 2006, 6:50pm
    I have all the brake lines removed at this time to prep. and paint my frame. I have and will be running factory axles at this point. I have and will be running the dual reservoir chevy truck one ton non power booster, like Robert Cowan likes to use. Any advice as to line routing? I was figuring on the factory location at this time, but could take into consideration a different routing for future one ton axles or rockwells, which ever I end up with first. Currently only have a corp. 14 bolt rearend. Any information regarding this is greatly appreciated. Fisherman
    Atlanta, Ga.
    Default bluesman2a :
    Re: Brake line routing.
    Post by bluesman2a on Aug 7, 2006, 7:34pm
    I completely rebuilt my setup using pretty much what you have. Bent my own lines too. I stuck with pretty much the stock locations. It just works. Only significant difference for me was to put in a separate distribution block for front/rear, and used the vinyl covered clamps you can get at raceshops, they work better than the stock clips.
  1. Brake line diameter??
    By DivingKaiser in forum Modified Tech
    Last Post: April 6th, 2010, 07:23 AM
  2. fisherman : Brake line pressure switch for brake lights.
  3. Brake Line Tools
    By Tomahawk715 in forum Modified Tech
    Last Post: November 2nd, 2009, 12:01 AM
  4. Brake Line Problem?
    By fisherman in forum Modified Tech
    Last Post: October 2nd, 2007, 10:13 AM
  5. Brake Line Routing Question!!
    By Nuke_spicergear in forum Stock Tech Archives
    Last Post: May 25th, 2004, 09:18 PM
