Results 1 to 10 of 14
Thread: gumball : Tilt Steering Column
    Default gumball : Tilt Steering Column
    Post by gumball on Aug 22, 2006, 6:38pm
    What factory tilt columns have members used and will a 98 s-10 column work?
    Default robertcowan :
    Re: Tilt Steering Column
    Post by robertcowan on Aug 22, 2006, 8:04pm
    FULL SIZE JEEP IS BEST
    Default jeepcj :
    Post by jeepcj on Aug 23, 2006, 7:16am
    I used a chevy car (full size) column, But I also have a C60 streering box
    Default tacomainoh :
    Post by tacomainoh on Aug 23, 2006, 1:06pm
    fullsize Jeeps basically used GM columns. They will fit but you need to hack the dash a bit, and come up with a new mounting scheme. I'll be using the complete FSJ mounts and pedals, and column. The mounting angles are different at the column. But it's not a huge engineering issue.
    40 Grit has some pics of how he did his.
    Default fasteddie :
    Post by fasteddie on Aug 23, 2006, 6:54pm
    Used a tilt column from a 76 C-10 chevy pick up . Wasn't to bad getting it in , did not have to modify dash .Had to cut off factory mounts from the column . Was able to hook up the column shifter for the automatic , neutral safety switch and back up lights , since this is a daily driver .
    Post by tacomainoh on Aug 23, 2006, 7:48pm
    How did you fit the fat Chevy column in the skinny M715 hole??
    Default kwai :
    Post by kwai on Aug 23, 2006, 10:27pm
    One word. "Sawzall. "
    Get you one.
    Post by tacomainoh on Aug 23, 2006, 11:40pm
    I know THAT lol...
    I am just curious because he said no mods, and my 78 Cherokee column, which is the same size, won't fit in the skinny dash cutout. It's thicker around than the stocker.
    Default fasteddie :
    Post by fasteddie on Aug 24, 2006, 7:44am
    Actually it's a M725 , but I figure the hole is the same . It fit in the floor board hole with no problem , didn't look like it was cut up before , still had original column in it . Upper mast mounting by dash panel was a little tight , if I remember right , I shimmed out the upper bracket some . I did not use the column ignition circuit so I just cut off the actuator rod from key rack to ignition switch which would have been a problem for clearance . Key only unlocks the steering wheel now . Did not have to notch out the dash panel , had good clearance .
    Default davea :
    Post by davea on Aug 24, 2006, 11:51pm
    Chevy vans with the ign key on the dash have skinny columns, and they were made this way until 82.
  1. Show me your Tilt Steering Columns
    By CrashMorriss in forum Modified Tech
    Last Post: October 30th, 2012, 11:26 AM
  2. Steering Column Parts
    By Barrman in forum Stock Tech
    Last Post: June 13th, 2008, 10:43 PM
  3. Steering column
    By archjr in forum Stock Tech
    Last Post: March 4th, 2008, 11:27 AM
  4. CJ Tilt column?
    Last Post: April 16th, 2007, 04:52 PM
  5. tilt steering???
    By soupy in forum Modified Tech Archives
    Last Post: March 25th, 2004, 12:34 PM
