Results 1 to 4 of 4
Thread: foreverunstopable : XL spring-over picture
    Default foreverunstopable : XL spring-over picture
    Post by foreverunstopable on Sept 1, 2006, 6:54pm
    Hi guys. Does anyone know the height a sprung over 715 on stock axles with 11.00R16's would be from ground to cab bow at its highest point?
    Default tacomainoh :
    Re: XL spring-over picture
    Post by tacomainoh on Sept 1, 2006, 8:10pm
    about 8-9" higher than it is now, roughly. Figure this :
    1/2 the difference in tire sizes+thickness of springs+1/2 the axle diameter. Off the top of my head that ought to give you your lift amount.
    Post by brute4c on Sept 1, 2006, 9:41pm
    Somewhere in that neighborhood....springovers give between 5 and 6 inches of lift and the tires are roughly 4 inches taller.....of which 2 inches actually raises the centerline of the axle....
    So 7 to 8 inches I would guess....
    Post by foreverunstopable on Sept 1, 2006, 9:43pm
    Thanks! want to make sure it will fit in the garage.
  1. foreverunstopable : XL Tubes and Flap
    Last Post: November 12th, 2009, 04:50 AM
  2. foreverunstopable : Lav Weight
    Last Post: November 12th, 2009, 02:38 AM
  3. foreverunstopable : Anyone have boots?
    Last Post: November 12th, 2009, 02:17 AM
  4. foreverunstopable : Hummer Wheels
    Last Post: November 11th, 2009, 12:49 AM
  5. foreverunstopable : Steering Problem
    Last Post: November 11th, 2009, 12:39 AM
