Results 1 to 3 of 3
Thread: barrman : Heater Fan Switch
    Default barrman : Heater Fan Switch
    Heater Fan Switch
    Post by barrman on Sept 5, 2006, 4:08pm
    How did the FSJ trucks turn on the heater fan and control the speeds? I can see a need for 3 cables to route the air and wonder if they had some kind of switch/cable unit. My '66 Chevy truck has that and if Jeep didn't do it, I will once I can find a source for them.
    Default compexp :
    Re: Heater Fan Switch
    Post by compexp on Sept 5, 2006, 4:28pm
    They had a 4 position fan control switch - off/low/med/high. there was also a cable-driven temp control slider similar to the chevy system.
    newer units had the a/c controls integrated in the same control area, buy mine is the older bolt-under the dash unit.
    Post by brute4c on Sept 5, 2006, 5:00pm
    The early ones used an all cable setup like the mil hot water heater for the M715 does though I have no idea what the fan switch positions were...the mil setup is hi and low...civvy could be 3 or 4 in the early ones I would guess....heres the cable setup diagram:
    15 turns on defrost
    16 turns on heat
    17 is the blend air door
    18 is the fan switch
  1. heater control cables and switch question
    By Duane in forum Stock Tech
    Last Post: May 9th, 2018, 02:43 PM
  2. Heater
    By chrisnwmsu in forum Stock Tech
    Last Post: October 3rd, 2009, 10:08 AM
  3. 12V heater
    By lumpyball in forum Open Discussion
    Last Post: December 3rd, 2008, 12:20 AM
  4. heater
    By foodstamp in forum Modified Tech
    Last Post: January 5th, 2008, 01:40 AM
  5. Heater box
    By Chumley in forum Stock Tech
    Last Post: October 10th, 2007, 04:24 PM
