Spark Plugs...
Post by shepsjeep on Nov 14, 2006, 7:24pm
Can someone tell me about the spark plugs for the 230 in general?
I have searched throughout this site and Military catalogs for the correct part numbers and places you can acquire them. This is what I found:
Manufacturer - Autolite
Part numbers 2344(resistor type), 2245(resistor type), 275 (non-resistor type) All available from NAPA (special order)
Prices - 2344 and 2245 are $7.80 ea and the 275 is $1.69
Which number should we use on a stock 230 engine?
I ordered a spark plug wrench and got it yesterday. Today I tried to take one out and found that they were frozen (rusted in). I sprayed some PB Blaster around the base and I am letting them soak. The wrench seems to work for the ends of the spark plug wires, but are nearly impossible to get around the base of the plug itself due to there being two plugs so close together. Is there an easier way to do this? Is there a socket available that will fit?
