Page 1 of 3 123 LastLast
Results 1 to 10 of 76
Thread: hummer103 : What Trailer to Pull a M715?
    Default hummer103 : What Trailer to Pull a M715?
    Post by hummer103 on Oct 16, 2006, 11:29pm
    I'm in the market for a trailer to pull my jeep. I might be moving to Arizona in the near future and would like to take my jeep with me and continue to use the trailer for wheeling trips, etc.
    I have a 02 Dodge Diesel so power on tap isn't an issue.
    I have a gooseneck setup which came with the truck and would love to get one but they cost considerably more $$$, are longer, and more difficult to store (Higher/Longer).
    There are tons of great deals on 16-20 foot car trailers with the deck between the wheels, but so many of these only have 3500 lb axles. They boast a 7000 lb payload but weigh in at about 1800 which leaves only about 5200 lbs for my jeep maybe a little more since all that weight isn't sprung weight.
    When I look at these same trailers with the 5200 lb axles, the deck gets narrower, b/c of wider tires and the price seems to increase significantly enough to make me look at goosenecks again.
    I want a 2-5/16 ball, don't need a dovetail and probably 2 axles with brakes.
    What are you guys towing with?
    I've gota 715 with a 350/465/205 and XL's so its weighing in more than stock, and I plan on hauling some stuff in the bed of the Jeep.
    I've read the posts about the U-haul trailer, and I'd rather do it right. Plus I could probably buy a trailer and sell it after moving and it would be cheaper than renting one to drive cross country.
    Thanks for any input,
    Scott
    Default oilcan :
    Re: What Trailer to Pull a M715?
    Post by oilcan on Oct 16, 2006, 11:36pm
    I use one of those lightweight 16-footers, and it really is too light. I've run at least 8,000 overloaded miles with only one blowout, though. Just lucky, I guess.
    I'd say get the biggest trailer you can physiclaay stuff in your chosen parking spot and be happy. You never know when you'll need to haul something big.
    Default compexp :
    Post by compexp on Oct 16, 2006, 11:58pm
    I've seen some used goosenecks fairly cheap - check your local craigslist and paper.
    Washington State
    Default fisherman :
    Post by fisherman on Oct 17, 2006, 12:15am
    I use a 16 " tandem axle, will hold 8,000 lbs. I always use towbars, and yes of course electric trailer brakes. Brought my M-715 from Pennsylvania to Washington state with a 96 ford powerstroke, worked great. Can't remember my trailer width but it is a couple inches wider than Binfords, I think two inches on either side of tires to edge of trailer.
    Default compexp :
    Post by compexp on Oct 17, 2006, 12:55am
    Joe/Ia has a really nice aluminum trailer with 9k axles - think he said it was about $4k though.
    Default joeia :
    Post by joeia on Oct 17, 2006, 7:01am
    It actually has 4800# axles which give it a GVW of 9600#. The trailer weighs 1600#, so it should be able to haul 8000#. As most of you know I did snap off all the studs on one wheel coming home from Tennessee in June. I do think it was due to overtightened lug nuts.
    Default jeepcj :
    Post by jeepcj on Oct 17, 2006, 7:46am
    If you can afford it get the Goose Neck. It's easier on your truck safer and besides the M715 you can haul lots of other things. I have a 26' with a wood deck. I bought it in GA fro under $3700
    Default kaiser715 :
    Post by kaiser715 on Oct 17, 2006, 9:02am
    Advantage to the g/n is that everybody you know can't borrow it. But then they'll want to borrow your truck too.
    I got a Kaufman 22' diamond car hauler, been really happy with it, whether hauling CJ, M715, or scrap. I wanted enough length to have room to balance out a bigger vehicle, or room for the CJ with a small trailer. 5200# axles, but titled at 9990# to avoid DOT regs and CDL.
    Get brakes on both axles -- what good is 10,400 capacity with only 520# worth of brakes?
    I had to get removable fenders. XL's/XZL's on stock wheels would fit between, on aftermarket wheels (bob cowan's) it's a couple inches too wide. Two bolts each side and they come off.
    Get the slide-in ramps instead of fold-up, in the past I've hauled a couple of big cars (station wagons) where the fold-up ramps didn't have room to fold up. And the truck bed was too full for them.
    For the coupler, I got an adjustable pintle hitch. It has about 10-12" of adjustment range using a vertical channel with holes drilled in it, and you can use either a pintle or a ball coupler that bolts into the channel. I'm trying to get the hitches on 3 different vehicles and 4 trailers to be halfway the same height.
    I got all the options I wanted, and custom build took about 4 weeks. Kaufman is a little far for you, but I'm sure there are good mfgr's up that way. Trailer was 3325.00
    G/N adds $500 to their trailers.
    http://www.kaufmantrailers.com/catalog.p....85a7b1570479a9e
    Default kaiser715 :
    Post by kaiser715 on Oct 17, 2006, 9:03am
    as for the width, you can also reinforce the fenders and drive over
    Auburn, AL
    Default snuffy :
    Post by snuffy on Oct 17, 2006, 9:55am
    I ran a 24' gooseneck RO/RO (Roll on/Roll off) to Utah - picked up my 715 ('the Goat') and rolled back to Alabama @ 80 mph. I had no issues what-so-ever.
    If you have a use for a good sized trailer - do it right the first time. Have a CM Trailers - Load Boss, electric brakes, 4' dove tail, 14,000 lb, dual axle with single wheels.
    Snuffy
    PS - Also hauls 40 LAV tires nicely... if that ever becomes an issue.
  1. Making M715 Bed Into Trailer?
    By krek in forum Modified Tech
    Last Post: August 6th, 2008, 11:20 PM
  2. These trucks can pull.
    By white433 in forum Open Discussion
    Last Post: February 12th, 2008, 04:38 PM
  3. another 3/4 ton trailer and m715 question
    By boghog in forum Stock Tech
    Last Post: May 15th, 2007, 08:50 AM
  4. M715 rims fit an M105 Trailer?
    By Elliott in forum Stock Tech
    Last Post: May 11th, 2007, 11:14 PM
