Results 1 to 10 of 11
Thread: barrman : Tow Bar Set Up
    Default barrman : Tow Bar Set Up
    Tow Bar Set Up
    Post by barrman on Nov 30, 2006, 9:45am
    I know this has been asked years ago. I just can't remember the answer.
    With the military tow bar. What is the recommeded length for using it? Which is better longers or shortest? I figure they put the 7 different length settings in there for a reason besides bumper clearance in tight turns. I could be wrong though.
    Thanks.
    Re: Tow Bar Set Up
    Post by brute4c on Nov 30, 2006, 10:31am
    No idea...that is something I would like to know...
    Default davea :
    Re: Tow Bar Set Up
    Post by davea on Nov 30, 2006, 10:42am
    Don't know about tow bars, but as a rule the longer a trailer tongue the better it pulls.
    May 2004
    Anchorage, Alaska
    Default 40grit :
    Re: Tow Bar Set Up
    Post by 40grit on Nov 30, 2006, 10:50am
    could it something to compensate for all the different vehicles that could tow/be towed...
    really wouldn't want a short tow bar behind a 5 ton wrecker, the crane part would whack the windshield/hood of the towed vehicle, along with turning radius considerations...
    Default elwenil :
    Re: Tow Bar Set Up
    Post by elwenil on Nov 30, 2006, 10:50am
    Keep it as short as possible. Here's a link to a PDF of the Towbar manual on SteelSoldiers. It's a very small file, just right click and "Save Target As".
    http://www.steelsoldiers.com/index.php?m....fid=file&pid=56
    For the record, it has a lot to do with the vehicle and how it is mounted, either using the shackle brackets, the bumper/axle clamps, etc. Hooking to the bumper wil require a lot less length than reaching back under the bumper to get to the axle itself.
    Re: Tow Bar Set Up
    Post by brute4c on Nov 30, 2006, 10:58am
    Thanks El!!!
    Default porkchop :
    Re: Tow Bar Set Up
    Post by porkchop on Nov 30, 2006, 11:00am
    Page three is nice.
    Default barrman :
    Re: Tow Bar Set Up
    Post by barrman on Nov 30, 2006, 11:05am
    Thanks Lanty. I looked through the SS manaul page for it before I posted this and must have skipped over it.
    Default elwenil :
    Re: Tow Bar Set Up
    Post by elwenil on Nov 30, 2006, 11:13am
    No problem guys. I had it on the PC at home and I knew I got it from SteelSoldiers a while back so I knew it had to be in there somewhere. It's sometimes hard to find the manual you want if you don't know the TM number with the many Deuce related manuals in there, lol. Glad I could help. There are also some interesting manuals on there relating to recovery that detail how the towbar is used with the various wreckers on different vehicles and situations. Interesting stuff.
    Default robertcowan :
    Re: Tow Bar Set Up
    Post by robertcowan on Dec 1, 2006, 1:12pm
    THE REASON ITS ADJUSTABLE IS THE M715 HAS NARROWER MOUNTING POINTS THAN THE M35 ETC. INSTALL IT AS LONG AS POSSIBLE AND IT STILL ALL PIN TOGETHER.
    BOB
  1. barrman : How Would You Do This?
    By Barrman in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 04:17 AM
  2. barrman : Hole Saw Use
    Last Post: November 12th, 2009, 02:51 AM
  3. barrman : Michelin PSI
    Last Post: November 10th, 2009, 11:34 PM
  4. Hey Barrman
    Last Post: April 17th, 2007, 01:27 PM
