Results 1 to 2 of 2
Thread: fng : Tool Box?
    Default fng : Tool Box?
    Tool Box?
    Post by fng on Dec 25, 2006, 12:08pm
    I have a question, Specifically what is the intended use of the long, pass through storage area in front of the bed? Was there some special purpose for this, like antenna storage or something?
    I think it wold be a great place to keep my Hi-Lift. Thanks, Tracy
    Re: Tool Box?
    Post by brute4c on Dec 26, 2006, 10:38am
    The compartment under the front of the bed is referenced in the Operators Manual as the stowage area for many of the issued items on the truck...the manual tells what the item is and then where it is stored...this description fits item that go in that compartment:
    Quote:
    In tool compt on R.H. or L.H. lower front side of body.
    Remember the cab is called the cab and the bed is called the body....
    These are the items listed for that area:
    BAG, Tool, Cotton Duck, 10" x 20"
    HANDLE, Jack, Flat Strip, ? x 7/8 x 20"
    JACK, Mach, Dbl-Screw, 3-Ton, Ratchet Type, 9" Closed, 18" Open
    WRENCH, Socket, Wheel Stud Nut, L-Hdl, 10.5" Offset, 1" Hex Opng, 24" long.
    EQUIPMENT FOR WINCH EQUIPPED VEHICLES
    BLOCK, Rigging, Wire Rope, Stl-Shell, Sgl-6 ? " Sheave, W/Swivel Hook, ?" Dia Rope & Under, 5-Ton Safe Work Load, OD Finish.
    CHAIN, Gen Serv, Sgl-Leg, High Test Chain, 7/16-Link x 10ft Long, W/2-Grab Hook, Proof Load 11,200 lb (Type I, Grade C, Class 2
    TROOP INSTALLED ITEMS
    SPOUT, Can, Gasoline, Flex, Cam Type, 2.25" OD x 16' Long.
    STRAP, Cargo, Tie-down, Nylon Webbing Univ Type, 1.75" Wd, 216" to 218" Lg Ratchet Buckle, W/2 Swivel Snap Hook
  1. tire change tool
    By osut362 in forum Modified Tech
    Last Post: May 16th, 2013, 09:48 PM
  2. clutch alignment tool
    By Duane in forum Open Discussion
    Last Post: January 27th, 2009, 12:55 PM
  3. Rich Brandi at Pro Tool
    By kalikraven in forum Open Discussion Archives
    Last Post: January 28th, 2004, 04:17 PM
