Crank Case Venting...
Hey guys,
I'm fiddling with my engine while I wait for a new flywheel to come in and I'm in need of some advice:
Working with a 4BT, stock hood mounted canister on the truck... Can I just run a vent line from the crankcase to the intake for the canister air cleaner??? This is how the stock engine was configured, but I didn't know if it would be a problem with a diesel.
As it sits, the crankcase vents straight to the bottom of the engine via a hose. Looking to make it water-tight for fording without a valve.
Problems, thoughts, suggestions...?????
Thanks,
Snuffy
Cummins - Turning fuel into noise since 1930.
