Thread: compexp : Parking brake adjustment
    Default compexp : Parking brake adjustment
    Post by compexp on Oct 14, 2006, 5:23pm
    My 715 had the parking brake messed up on it when it arrived. It was missing the locating bolt on the left side as you look from the rear.
    I replaced the bolt - but when I tighten the bolt up, the brake seizes the parking brake. I thought this bolt was just to hold the left side of the parking brake on?
    Has anyone else had this issue? I'd hate to have that locator bolt fall out and have the brake bind up, but if I don't leave it at least a little loose, I can't move the truck.
    Any advice out there?
    thanks
    rich
    Default oilcan :
    Re: Parking brake adjustment
    Post by oilcan on Oct 14, 2006, 6:15pm
    Mine didn't have the locating bolt, and worked ok for the most part, but I finally got around to sticking a bolt in it after the FE. I found one a lot longer than it needed to be, so I wouldn't have the trouble you're describing. A little blue loctite holds it in just fine.
    Default firefightinsam :
    Post by firefightinsam on Oct 14, 2006, 6:45pm
    You could double up the nuts on that bolt and tighten the nuts against eachother.
    Default compexp :
    Post by compexp on Oct 14, 2006, 6:52pm
    Well, what I'm wondering is if by tightening that bolt all the way that it's somehow tightening the brake - it doesn't look like it would.
    In the parts manual, it shows a spring between the outer part of the parking brake and the screw point in the xfer case itself. I don't think my spring is there. I think what that spring does is to help hold the left side of the brake band off of the drum.
    Default binfordm715 :
    Post by binfordm715 on Oct 15, 2006, 9:54am
    Rich, did you find the instructions for adjusting the parking brake in amongst the manuals? They have a pretty good description of what to do.
    If I'm understanding you correctly, you're talking about the bolt that runs horizontally from the driver's side toward the passenger side, on the driver's side of the e-brake, right? As I recall, that gets tightened until the gap between the band and the drum is 0.015". Then the gap is set to the same at the 1- to 2 o'clock and 4- to 5 o'clock positions by adjusting the J-bolt nuts and the nuts on the smaller bolt outboard of the J-bolt.
    Oh, and there's supposed to be a safety wire through the head of that bolt you were talking about. Nothing to prevent it from backing out (can't jam-nut it).
    Default compexp :
    Post by compexp on Oct 15, 2006, 6:49pm
    Tim, thanks for the info - I hadn't delved that deep into the manual yet - been busy prepping for Halloween.
  1. disc parking brake
    By osut362 in forum Modified Tech
    Last Post: May 11th, 2011, 01:30 PM
  2. alex : Parking brake
    Last Post: November 12th, 2009, 07:46 AM
  3. Parking Brake Specs
    By Jester in forum Stock Tech
    Last Post: September 9th, 2008, 12:06 PM
  4. Brake adjustment wrench
    By vacca rabite in forum Open Discussion
    Last Post: August 19th, 2008, 11:44 AM
  5. Hydro parking brake
    Last Post: January 2nd, 2004, 03:46 PM
