Results 1 to 9 of 9
Thread: fastfrankie : Stock points/condensor/dwell/etc.
    Default fastfrankie : Stock points/condensor/dwell/etc.
    Post by fastfrankie on Dec 3, 2006, 3:18pm
    Where can I get some new points and condensor for my stock 24 volt 230? AB Linn? I am sure Memphis has them but they are pricey...I wonder if these could be had at a local NAPA? Part numbers?
    What gap do people use? The .020 stock setting?
    How do I hook up my dwell meter? I have an old style dwell meter with needle and a newer digital one? What one is better to use? Any help on how to hook it up etc would be great.
    My truck was always hard to start, especially cold, regardless of what the temperature was outside - summer or winter. I go to check the points and the screw was loose on the holdown and the point were at about .010. I regapped the points to .020 and now it runs/starts fairly quick. The old points do look a bit worn though...
    Thanks, Frank
    Default kwai :
    Re: Stock points/condensor/dwell/etc.
    Post by kwai on Dec 3, 2006, 5:12pm
    AB Linn usually has them.
    Default mthomsen :
    Post by mthomsen on Dec 3, 2006, 7:13pm
    The napa part numbers-
    Points- Echlin #Cl725A
    Condensor- Echlin #A131a
    If you have a carquest near, here are the numbers for them.
    Points- AL4556xp
    Condensor- AL118x
    Rotor- AL154 (note, this rotor takes some very minor modification to miss the condensor)
    Basically make it look like the one that you take out.
    I use the .020 setting for the points.
    Post by brute4c on Dec 4, 2006, 11:04am
    That is the right points gap....to hook up a dwell meter one needs to know what the particular meter wants...mine is a Sears unit and it hooks up with one lead clipped to coil negative and the other to a good ground. I prefer the dwell method myself.
    Which unit would be better? As long as they are both accurate, its probably a moot point.
    The dwell setting for a stock military ignition:
    38? to 44?
    An ignitor dwell angle of more than 44? (small gap) may cause hard starting. A reading of less than 38? (large gap) may cause engine to misfire at high speeds or underload.
    Post by fastfrankie on Dec 4, 2006, 1:22pm
    Brute....
    How do I hook up the dwell lead to the coil wires since the coil is encased under the cap housing? Do you remove the large bolt/cover on top of the distributor cap housing to attach the lead to the coil negative?
    Also, those NAPA numbers for the points and condensor are no good at my local NAPA...the guy plugged them in and had no luck. I Guess I will have to call AB when I get home...the only thing that's a bummer about him is that he doesn't take credit cards....that mean I have to go and get a money order and mail it to him which delays everything an additonal week....
    Post by brute4c on Dec 4, 2006, 1:43pm
    The big hex on the ignitor housing cover over the coil is the place to go through to hook up to coil negative. That is the test port for diagnostics anyway...so that is the place.
    SF Bay Area, CA
    Default hiker :
    Post by hiker on Dec 4, 2006, 3:33pm
    Try these NAPA parts, They work, but a bit pricey. show available Echlin brand:
    Contact set (points) CS 725A $13.49
    http://www.napaonline.com/MasterPage...PartNum=cs725a
    Condensor AL869 $7.49
    http://www.napaonline.com/MasterPage...&PartNum=AL869
    Rotor AL166 $10.49
    http://www.napaonline.com/MasterPage...&PartNum=AL166
    Default mthomsen :
    Post by mthomsen on Dec 4, 2006, 6:02pm
    The numbers i listed were old numbers, hikers numbers are the cross for the old ones. Parts guy just was to lazy to get the book out, and cross them.
    Post by fastfrankie on Dec 4, 2006, 7:34pm
    Well I ordered a set of points from AB Linn...$11 shipped to my front door.
    I went to start my truck today cold and she just cranked and cranked. The points were a bit worn and rough so I guess I will replace them when I get the new points and go from there. I have had this problem for a while now. I will recheck the timing now that I gapped the points the other day to see where I am at. I am at wits end with this hard starting problem!!
  1. binfordm715 : How do I hook up my dwell meter?
    By Binford in forum PseudoZone - Stock Tech Archive
    Last Post: December 15th, 2009, 02:58 PM
  2. ignition condensor
    By 5quarter in forum Stock Tech
    Last Post: January 26th, 2009, 11:52 PM
  3. Points and Condenser for Stock Distributor
    By rboltz in forum Stock Tech
    Last Post: December 22nd, 2007, 08:01 PM
  4. Dwell meter
    By adk4x4 in forum Open Discussion
    Last Post: April 30th, 2007, 05:00 PM
  5. Points & Dwell
    By law in forum Stock Tech Archives
    Last Post: March 1st, 2004, 10:04 AM
