Results 1 to 9 of 9
Thread: alosix : DS drop front axle?
    Default alosix : DS drop front axle?
    DS drop front axle?
    Post by alosix on Nov 21, 2006, 8:24am
    Finally aquired the drivetrain for the M725. Wanted diesel, but didn't want to pay for it. Have a complete 5.7 Hemi/trans/t-case on the way now from a 2005 1500 pickup.
    This means DS drop front end. I'm 1/2 tempted to put the 2nd gen dodge 5 link up front and use a D60/D70 combo out of one of those trucks.
    Looking for any other suggestions. Would stay leaves if I can get the axle at a decent price.
    Thanks,
    Jason
    Default tacomainoh :
    Re: DS drop front axle?
    Post by tacomainoh on Nov 21, 2006, 11:06am
    Uhmmmmm get a Dodge axle??? Ford???
    Or see if an older Dodge 205 will fit on your trans. That's what I did w/the Cummins I'm putting in (again) my 87 Chevy.
    Default davea :
    Post by davea on Nov 21, 2006, 11:10am
    Late 80's/early 90's Ford F350's used a drivers drop D-60 and if you run spring over, the factory ford spring pads are in exactly the right place for the M trucks. only drawback is that the factory ford steering arms put the pass. side tie rod pretty close to the bottom of the spring pack. Has clearance in rest mode, but might rub during flex. Plus it has locking hubs and inner/outer wheel bearings vs. the Dodge's hubless, mono bearing setup.
    Default wi715 :
    Post by wi715 on Nov 21, 2006, 11:13am
    You could use Dana 60 out of a 86-91 F-350.
    I'm using 1 out of '88. mounts used were Ford on the driver's side, Chevy on pass. side.
    Got 2 for sale near Wi Dells WI.
    John
    Default davea :
    Post by davea on Nov 21, 2006, 11:16am
    John, beat you to it. LOL
    Default wi715 :
    Post by wi715 on Nov 21, 2006, 11:22am
    Thats just because I type with 2 or 3 fingers
    Default davea :
    Post by davea on Nov 21, 2006, 11:29am
    I sent you a pm with a question. I wanna pick your brain since you have your steering ironed out.
    Default alosix :
    Post by alosix on Nov 21, 2006, 11:38am
    Was mostly looking for years of Dodge/Ford that might be useful.
    Kinda like the idea of running the late model 241 that's coming with it.
    Does the steering of the fords work ok if sprung under? Not looking to make this one any taller. Its going to most do parts hauling and light tow duty.
    Thanks,
    Jason
    Default davea :
    Post by davea on Nov 21, 2006, 11:43am
    John
    I think top mount steering arms would work if you ran it spring under. You might have to blue-flame the stock arms off.
  1. robertcowan : FRONT 8 LUG HUBS THAT FIT THE M715 FRONT AXLE
    Last Post: December 15th, 2009, 09:14 PM
  2. Need front axle measurement
    By scottsmyth in forum Stock Tech
    Last Post: September 19th, 2009, 06:10 PM
  3. front axle lubrication
    Last Post: November 13th, 2008, 06:35 PM
  4. front axle locker
    By fwdstuck in forum Modified Tech
    Last Post: May 20th, 2007, 08:20 PM
  5. m715 front axle
    By heepofajeep in forum Open Discussion Archives
    Last Post: May 24th, 2004, 10:29 AM
